Results 1 to 10 of 10
Thread: ROS Pad Question
    Dec 2008
    Portland, Oregon
    1,898
    ROS Pad Question
    I have a B&D ROS, and the velcro keeps coming off the pad. I've replaced the pads twice with new ones and re-glued the velcro at least 5 times. I've used everything from contact cement, titebond, craft glue, spray on glue. I clean both pieces well with denatured alcohol before I apply the glue.
    Anyone else have this problem??
    Jesus was a Woodworker
    17,475
    i havnt had this problem dan, maybe its time to change to a bosch or other brand. got porter cable's that are still working for over ten years.. have switched to bosch last couple years because of the dust factor and better abrasive pattern.
    Oliver Springs, TN
    1,726
    I agree with Larry. It might be time for an upgrade.
    I had that same sander and never could get the replacement pads to stay on, it can get real exciting when you lift the sander up with it running and the pad and paper go flying across the shop....DAMHIKT...
    Austin, Texas
    1,448
    Quote Originally Posted by Dan Mooney View Post
    Both Titebond and Craft Glue are intended for porous surfaces like wood, fabric, leather, paper. These are not porous.
    The generally available spray-on glues are not strong - they are great for holding a pattern to a piece of wood for sawing, but not structural.
    I am surprised that the contact cement didn't hold, but maybe it is because it does not withstand heat, and a sanding pad can get warm.
    As much as I generally hate Polyurethane glue, I did fix one sanding pad with poly (different type of sander) and it worked.
    Charlie Plesums, Austin Texas
    Thomasville, GA
    5,998
    Another thought about the pads coming loose: How much pressure are you applying to the sander? The weight of the sander should be enough to do the job when using the right grit. Applying a lot of pressure to "help" the sander will cause the paper and pad to heat up and cause adhesive failure.
    Yep - speaking from personal experience.
    Bill Arnold
    10,604
    I say try another brand as well. I have a Porter Cable 333 ros for well over 10 years and the sandpaper still holds like it was new. I can't even think about how many 5 hole disks I've gone through. It's gotta be well over 600.
    Nov 2010
    Arkadelphia, Arkansas
    139
    I've got a 6" PC that I bought in the mid 90s. I'm one of those 'odd ball' woodworkers who enjoy sanding. As a result I've gone through ALOT of sandpaper on that tool. NEVER had any of it come off on it's own. I agree with whats been said previously........time to upgrade!
    Norm
    I have a mind like a steel trap....
    ....rusty and illegal in 29 states.
    heck Bob, used more then that on the Church Commission...lol
    The Heart of Dixie
    4,268
    I have a Bosch sander that they no longer make a replacement pad for. I bought velcro to replace mine once it wore off. I have never found anything that would keep the replacement on for very long. 5 minute epoxy works best, but not great. So no, your not alone.
    Custom built boats and Kits
