Results 1 to 10 of 10
Thread: Door Hinge Jig?
    13,360
    Door Hinge Jig?
    Does anyone have any advice for either a DIY or store bought jig to route the hinge mortise for doors?
    We are replacing a bunch of doors in the house and I'll be having to do a bunch.
    It'd also be good if it does the door side strike plate as well.
    Just replacing the doors, not the entire casing, so I'll be needing to make sure the doors fit the existing hardware locations.
    Back about 30 years ago I rented one from a local rental yard. Much cheaper than buying something I would probably never use again and I could rent a higher quality one than I could afford to buy. Just food for thought.
    Sep 2007
    Plainwell, Michigan
    4,857
    Here is a neat setup that works for all type of hinges originally posted by Tod Evans http://familywoodworking.org/forums/...nge&highlight=
    13,360
    Well Howdy Doody, that's just what I'm looking for Tom. Simple enough even I should be able to make it work.
    Thanks!
    Dec 2008
    Santa Claus, In
    4,779
    I am going to go against the grain and suggest this. http://www.toolbarn.com/portercable-59381.html Works very well and repeatable. Everything is factored in. If I had a bunch to do, this is what I would use.
    Rule of thumb is if you don’t know what tool to buy next, then you probably don’t need it yet.
    13,439
    Are you replacing the jambs as well or just the door panels? I've got the jig Steve posted and unless you're doing the jambs too, it may be overkill. They make some smaller plastic templates that the blue borg used to carry for doing just a hinge at a time. I'd suggest those or making your own for doing just panels. Reason is that you can set the new door next to the old and mark the exact locations and making fitting them to the old jambs easier.
    Edit: Like these, they make them for both the squared and large radius cornered hinges. http://www.toolbarn.com/portercable-59370.html
    Can also make your own. You'll also need the template for routing the recess for the strike plate/plunger. I made one of those as well, but have one I purchased too.
    Here's the strike plate/latch template: http://www.newegg.com/Product/Produc...9SIA0580009Z08
    hmmm I never did a bunch but I do it the way my Dad taught me, trace the hinge, use a chisel and wamb bamm thank you m-- they are done in no time at all., free hand. I guess I am a knuckle dragger at heart.
    NH
    4,005
    hmmm I never did a bunch but I do it the way my Dad taught me, trace the hinge, use a chisel and wamb bamm thank you m-- they are done in no time at all., free hand. I guess I am a knuckle dragger at hart.
    Even when I have a bunch to do that's how I get em done
    Stupid hurts.
    13,360
    If the corners of the hinges were square, I'd consider that. These have a radius on the corners. I think I'd rather have the corners match the hinges in that case.
    I'm going to go with Tod's 25 cent jig. Thanks!
    Jun 2010
    Croton, Ohio (about a half hour NE of Columbus)
    154
    I had a few doors to hang when we bought this house a few years ago so I picked up one of these at the BORG.
    http://www.portercable.com/Products/...roductID=16391
    It worked pretty well for what I needed it for. There is a matching strike plate kit that works pretty well too.
    Normally I'd do the chisel and mallet thing too but I had 8 doors to do and wanted to get them done a little quicker.
  1. door hinge positioning
    Last Post: 03-09-2015, 07:45 PM
  2. No Bore Glass Door Pivot Hinge
    By mike marvel in forum General Woodworking Q&A
    Last Post: 07-23-2012, 04:01 PM
  3. Cabinet Door Hinge Question
    Last Post: 04-20-2011, 12:12 PM
  4. Door hinge template jig?
    By Mark Rios in forum Carpentry and Construction
    Last Post: 03-09-2008, 12:05 PM
  5. 25 cent hinge mortising jig for any hinge
    By tod evans in forum Jigs and Fixtures
    Last Post: 03-20-2007, 12:10 AM
