Results 1 to 7 of 7
Thread: Box Joint Jig
    Dec 2008
    Portland, Oregon
    1,898
    Box Joint Jig
    I have a Box Joint Jig that I've used for several years for 3/8"x3/8" wide notches, I had to make some 3/8"x3/4" and when I went back to the 3/8"x3/8" I was getting tear-out because there was nothing behind the top of the cut after cutting the taller 3/4".
    So I used a dovetail bit to cut a sliding dovetail slot and a piece that fits snugly in the slot so when I change the size of the box joints I can change the backer.
    Jesus was a Woodworker
    Independence, Kentucky
    1,355
    Nice save Dan, that should work really great
    13,364
    Great idea Dan!
    12,264
    Way to go, reminds me of the magazine for a galtlin gun. When its eaten up you just feed it in some more.
    9,077
    Very cool Dan. I like that you can use longer stock and just cut off the end as you change. I wonder if I could reverse engineer that into my crosscut sled for dados . . . . hmmmm?
    10,604
    Great idea Dan !!!
    Thomasville, GA
    6,000
    That's what I like: a simple solution to a problem! I like simple.
    Bill Arnold
  1. Joint Cam
    By Darren Wright in forum Programming, Troubleshooting, and Q&A
    Last Post: 03-11-2015, 08:57 PM
  2. How would you cnc a corner joint
    By Rob Keeble in forum Programming, Troubleshooting, and Q&A
    Last Post: 09-27-2014, 10:57 AM
  3. Finger joint Box
    By Ron Roase in forum Flatwork Project Showcase
    Last Post: 01-23-2010, 10:26 PM
  4. seeking name of joint
    By Bill Simpson in forum General Woodworking Q&A
    Last Post: 09-30-2009, 11:49 PM
  5. M and T joint ?
    By jim capozzi in forum General Woodworking Q&A
    Last Post: 02-01-2009, 04:51 AM
