Results 1 to 10 of 13
Thread: Drawer slides- Wooden
    17,470
    show me your examples of wooden drawer slides and how you put them into the piece that you have made.. and any tips on what to do to make it easier.. i have 3 dressers to make and have heard that wooden slides are the best approach to this..i have used the pre-made ones in a hutch and i also have used the hanging style on the sides with hardwood but not this many and on 36" wide drawers.. so mike show me the tricks you got alot of drawers in the shop
    P.S charlie plesums your lingerie link in your web page didnt work
    5,319
    Hey, Larry,
    You might want to try the archives of the Hand Tools forum over at Wood Central. A while back there was a very long and spirited discussion of drawer glides and slips. As I recall Derek Cohen (member here, too) had a lengthy treatise on the subject, too.
    17,470
    well jim the last time i was on wood central they would answer one single question from me so i went to smc and got answers the first day way back when.. and even meet some of them at the five barn picnic later on..the wood central folk.. so i will go see what derek has to say it might be on his site as well")
    Have a couple of the mounting holes oversized to allow adjustment. Then the remaining holes can be used to lock the rail in place. On 36" I would consider a center guide on the bottom as well.
    Attached Thumbnails Attached Thumbnails drawers-4-002.jpg   drawers-4-006.jpg   drawers-5-001.jpg   pre-finish-elevations.jpg
    Austin, Texas
    1,448
    Hi Larry... there are two methods I have used...
    The classic approach is to have a frame between each drawer (also holds the dust shield). I make the sides about 1/16 inch thicker than the front, which is finish wood, so the drawer doesn't scratch the finish wood. Build the frame with 1/32 or so above, and 1/32 or so below the front of the frame - just enough to keep the drawer bottom (and top) away from the front piece.
    That classic approach doesn't keep the drawer centered, so I am moving towards plan B - side runners mounted on the front and back of the carcase (so that it straddles floating panels on the sides, for example). Those runners are just under 3/4 inch high (to fit in a 3/4 inch dado in the sides of the drawers. The dado is about 1/4 inch deep in the drawer (thus requiring drawer sides 5/8 " or more thick. The runners are about 3/8 inch thick - to hold the drawer centered and provide clearance on each side.
    If you have an overlay drawer, the drawer front determines the depth the drawer closes... the runner only has to be close. If you have an inset drawer front, you can get fancy with a stopped dado, and let the end of the side runner stop the drawer. Easiest way I have found is to trim the end of the runner to adjust the drawer depth. See http://www.plesums.com/wood/bedroom/lingeriechest.html for an example of the inset drawer front with the side runners... in that case, I played with the dovetails so the runner was in a wide pin. In the chest in my shop now, I purchased the drawers unassembled, cut the dado in the sides, assembled the drawers, cut the dado through the back on the shaper, and squared off the stopped dado on the front with hand chisels.
    Last edited by Charlie Plesums; 01-05-2012 at 10:45 PM. Reason: dovetial tail vs. pin
    Charlie Plesums, Austin Texas
    17,470
    is it just me or does the link from charlie not work?
    Yorktown, Virginia
    5,005
    Works for me larry
    Jul 2007
    DSM, IA
    5,719
    Works for me too.
    My Website
    5,319
    I guess it's just you, Larry! Works for me, too.
    17,470
    me too now???? it wouldnt this am though..
  1. Wooden Drawer Slides?
    Last Post: 03-08-2011, 05:20 PM
  2. Drawer Slides
    Last Post: 08-06-2010, 01:30 AM
  3. Drawer slides
    By Paul Downes in forum General Woodworking Q&A
    Last Post: 01-29-2009, 03:37 PM
  4. FYI Drawer slides
    By Bill Simpson in forum General Woodworking Q&A
    Last Post: 09-16-2008, 01:10 AM
  5. Drawer slides?
    By Brent Grooms in forum General Woodworking Q&A
    Last Post: 02-02-2007, 02:32 AM
Tags for this Thread
