Results 1 to 10 of 12
Thread: Edge rounding / cornering plane or tool
    Central PA
    638
    I am looking for a tool to ease or round the edges of boards, I see that lee valley has a few things that will accomplish that
    http://www.leevalley.com/US/wood/pag...01&cat=1,41182
    http://www.leevalley.com/US/wood/pag...82&cat=1,41182
    http://www.leevalley.com/US/wood/pag...84&cat=1,41182
    What do you guys use. I have used a regular block plane in the past but when I was doing a bunch of pieces I ended up with some parts more rounded that others, and depending on how much of a hurry I was in I didn't notice until too late.
    12,251
    router with curved bit.
    Dave you know if you want a chamfer lv has a small attachment for the block plane that will give you a chamfer
    Central PA
    638
    I have been using a router lately but my smallest round over is 1/16" radius which is kinda big for some stuff, I just like the idea of being able to grab a tool and do it quickly without having to setup the router. I usually want a round over, not a chamfer.
    Jun 2007
    4,944
    Hi,
    I have owned and used number one and number two. Yes they work. Yes it is VERY EASY to screw up with them. I would avoid them. Unless you hold them just right they can give different results. They can catch in the grain and pull up a whale of a lot more wood than you want them to. For building a back deck or a set of outside stairs I would try one if I had it. However, I sure would not even let either of them in the same room with a piece of furniture to be wood.
    I had two cheap versions of number three (chamfer and rounding) from Rockler. All they built was my frustration. I gave them to Glenn and he couldn't make either of them work well enough that he would use them near furniture quality wood either. I am quite sure he trashed them.
    I have never had a problem with Lee Valley. You might try the third one. If it does not work, return it. However, I think that there has to be a better way. If you can get to the wood with a router, use it with a rounding bit. That seems to work all of the time for me. I am sure that Glenn uses a router for this type of thing also. Glenn is the type of person who looks into everything. He reads all of the magazine articles to help him make a decision. When possible he uses scrap wood to try any tool he can beg or borrow before spending his money.
    I hope this helped.
    Enjoy,
    JimB
    VOTING MEMBER
    Jun 2007
    4,944
    Hi Again,
    Your 8:00 post was not there when I started writing my reply. When all I want to do is soften an edge I use the Sand-Flee Finishing-Mops. I have a 400, a 220 and a 120 grit. If I had only one I would choose the 220. We built a desk for the boy next door to take to college. We finished all of the edges with the 220. It worked great. It is fast and easy to control.
    Enjoy,
    JimB
    VOTING MEMBER
    I have always used a router and a number of different bits, depending on the size of the roundover
    Anybody can become a woodworker, but only a Craftsmen can hide his mistakes!
    The Bible tells us to love our neighbors, and also to love our enemies; probably because they are generally the same people.
    17,472
    dave i have this one that you linked to and like it alot..LINK but you do need to watch the grain direction where as in a router thats not as important..
    Central NY State
    3,374
    A block plane will do nicely. If you're concerned about matching and accuracy, you can draw pencil lines, and plane to them. If you're looking to make roundovers less than 1/16", then a couple swipes with a plane and some sandpaper will be fast and easy.
    Thomasville, GA
    5,992
    Power tool junky here. Router and assortment of bits down to 1/16". Past that, a few swipes with 150 sandpaper knocks it off.
    Bill Arnold
    Central PA
    638
    well for now I think I will use a combination of a block plane and router. I was afraid that the specialized planes would be prone to tearout.
  1. How to plane/flatten large live edge boards bigger than 20"
    By Sam Keays in forum General Woodworking Q&A
    Last Post: 06-01-2015, 01:55 PM
  2. Squaring edge of toothing plane blade
    By Jim Moore in forum Neander Woodworking Q&A
    Last Post: 05-15-2014, 02:18 PM
  3. New LV LH Edge Plane
    By Doug Shepard in forum Neander Woodworking Q&A
    Last Post: 09-04-2007, 11:31 PM
  4. looking for straight edge and wood threading tool
    By Darren Myers in forum Old Ads
    Last Post: 06-12-2007, 11:48 AM
  5. New edge plane profiles from BCTW.......
    By Mark Rios in forum General Woodworking Q&A
    Last Post: 11-14-2006, 01:13 AM
