Results 1 to 5 of 5
Thread: Narrowing down how I finish my turnings - Question
    Palm Springs, Ca
    1,167
    I always play around with finishes with my projects and find like most of us I like certain products and other ones not so much. The finishes I use most all the time now adays is oil finishes - laquer - Ren wax
    Picture 1 - dyed green coffee mug sleeve - finished with analine dye and 5 coats of laquer -0000 between the coats and final coat - EEE
    applied with lathe running at about 1200rpm - let dry for 30min and hand buff lightly
    Picture 2-3 - Some scrap pine turned coffee mugs sleeves - DO applied 3 coats with 0000 between each - then 4-5 coats ML Campbell laquer with 0000 between
    each - then Ren Wax applied as above - much higher gloss than the green one
    Picture 4 - Mug sleeve with two coats of DO on - will go with three and then some type of finish
    Picture 5 - Another sleeve with first coat of Formby Tung - sanded in with 400 - wiped well and out drying - finish unknown yet
    Picture 6 - Two larger vessels with analine dye - several coats of Deft laquer - 0000 between each coat - coat 3 drying on each - finish unknown
    Picture 7 - Small NIP vessel - oil/varnish appled - now drying out
    Picture 8 - Large vessel 2' long - sanded to 600 with MS - now drying - finish pending
    My common finish that I like is with oil as the first few coats and then on to laquer and finishing them in semi gloss to gloss finish. Sanding and/or using 0000 between
    coats of finish. Wax is always Ren wax when I do use it - sometimes the last coat of laquer looks great and I leave it.
    Question: I am wondering how other turners are finishing their turnings using oils and laquer ???????
    Attached Thumbnails Attached Thumbnails P1010004.jpg   P1010007.jpg   P1010010.jpg   P1010012.jpg   P1010013.jpg
    Jun 2007
    4,944
    So far I am no help to you. I use one or more of the following: BLO, no wax shellac, wax, clear satin spray can.
    I, almost always, prefer a satin or matt finish.
    Enjoy,
    JimB
    VOTING MEMBER
    30,008
    When I use lacquer over an oil finish (or an oil-based wipe-on varnish like Formby's Tung Oil Finish), I like to let it cure for a couple of weeks before I hit it with the spray can lacquer. If it's BLO, I'll give it a month or so. I'll use 400 or 600 grit paper (typically moistened with water) between the coats if there are any dust nibs to get rid of.
    Palm Springs, Ca
    1,167
    Vaughn - do you find that the 400+ wet sanding is doing better than 0000 ? I do the same using 0000 if there are any specs, streaks or ? on the turning otherwise build up the laquer until I get the finish I think looks good.....are you leaving the laquer finish or using Ren after?
    Goodland, Kansas
    4,834
    I use basically walnut oil or polymerized tung oil for my finishes utility items. I use shellac followed by lacquer on ornaments, mini birdhouses, etc. On HF's, vases, etc I may use antique oil, WOP, General Finishes Seal-A-Cell followed by Arm-R-Seal. I don't use lacquer, poly or any other finish over them as I have never seen a need to. I do like Vaughn and wet sand with 600 or 800 grit which I think leaves a extremely smooth and even surface. Generally I beall buff (except utility items) after the last coat has cured for a minimum of 10 days to two weeks using Ren wax for the last wheel.
    Bernie W.
  1. Narrowing the Generation Gap
    By Paul Douglass in forum Off Topic Discussion
    Last Post: 02-05-2016, 06:30 AM
  2. Acrylic spray finish on turnings
    Last Post: 04-26-2014, 11:53 AM
  3. Spray Finish on Turnings
    Last Post: 04-26-2014, 03:29 AM
  4. Finish Question
    Last Post: 07-03-2011, 12:04 AM
  5. To finish or not to finish - That's the question!
    By Bruce Shiverdecker in forum General Woodturning Q&A
    Last Post: 01-10-2007, 04:22 AM
