Has anybody ever tried PSA backed veneer on glass? Thanks, DKT
D Dietrich Trenner Member Messages 178 Jan 13, 2012 #1 Has anybody ever tried PSA backed veneer on glass? Thanks, DKT
Bill Arnold 1974 Staff member Messages 8,633 Location Thomasville, GA Jan 13, 2012 #2 I've never tried it, but found this article at Joe Woodworker. Just curious - what's the application?
larry merlau Member Messages 18,741 Location Delton, Michigan Jan 13, 2012 #3 he is after a glass finish without using the lacquer build
Bill Arnold 1974 Staff member Messages 8,633 Location Thomasville, GA Jan 13, 2012 #4 larry merlau said: he is after a glass finish without using the lacquer build Click to expand... Yep. That should do it! You are SO bad, Mr. Merlau!!!
larry merlau Member Messages 18,741 Location Delton, Michigan Jan 13, 2012 #5 Bill Arnold said: Yep. That should do it! You are SO bad, Mr. Merlau!!! Click to expand... Larry, just Larry is fine
Bill Arnold 1974 Staff member Messages 8,633 Location Thomasville, GA Jan 13, 2012 #6 You are SO bad, just Larry!
D Dietrich Trenner Member Messages 178 Jan 13, 2012 #7 "What's the application?" My wife and I do a lot of work with stained glass, so we thought trying veneer would extend our options. From your article PSA veneer should work, so we'll try it out. Thanks, DKT
