Results 1 to 10 of 23
Thread: Cutting Laminated Counter Top..***Final Stages***
    Tokiwadai, Japan
    2,882
    I'm installing a premade laminate counter top in our laundry room and need some advice on cutting it to length. Has anyone here done this before?
    I need to cut just shy of 2 feet off.
    I have a DeWalt 36T thin kerf finish blade...will this be OK?
    I found an article with a jig that seems to be a good way, but would like to hear from those who have done this before.
    http://www.woodworkingtips.com/etips/etip022500wb.html
    Thanks.
    33.8736N, 117.7627W
    435
    Every time I've ever seen the subject come up, "cut long and belt-sand to length" seems to be the winner. I'm not sure it's possible to get a clean cut with the backsplash already attached.
    Where are we going? And what am I doing in this handbasket?
    Constantine, MI
    8,016
    Quote Originally Posted by Lee DeRaud View Post
    What Lee said + cut from the underside, laminate down.
    www.wrworkshop.com
    greg, lee and rennie are both right......cut from the bottom........if you`re good and the stars are aligned right you might get a servicable edge off the saw.......if not beltsand being sure to pull the laminate into the substraight...tod
    Tokiwadai, Japan
    2,882
    Thanks guys,
    I've just about got the jig built. I'll also put masking tape on the laminate side, but cut from the back...a bit long and sand.
    Contoocook, NH
    129
    Smile
    I cut from the top after applying masking tape to protect it.
    Used a jig saw, worked pretty well. Just go slow.
    Richard "Butch" Leshner
    Constantine, MI
    8,016
    Quote Originally Posted by Richard Leshner View Post
    You can actually buy a jigsaw blade that cuts on the down-stroke - especially made for cutting laminate from the top. Works pretty well. The big boxes carry them.
    www.wrworkshop.com
    1,289
    Hi Greg,
    I just trimmed up an edge on this corner counter top I found with the Festool TS 55 and rail. I cut about two inches off the end. I did it from the bottom as you suggested and it made a baby smooth cut on wood and laminate.
    If you have a good guide and a good blade you shouldn't have any problem.
    (Oop's) I did take the back Splash off so I didn't have that to worry about. I'm not going to use it in my project.
    DT
    Tokiwadai, Japan
    2,882
    Has anyone tried the Bosch T234X jig saw blades on laminated MDF?
    Quote Originally Posted by Greg Cook View Post
    yup they dull fairly quickly......better luck with a fine tooth blade....tod
  1. Cutting Board with Laminated Inlay - Last Minute Christmas Request
    By glenn bradley in forum Flatwork Project Showcase
    Last Post: 12-09-2014, 12:43 PM
  2. Final New Design Razorback / Word Art Cutting
    By Marshall Border in forum Flatwork Project Showcase
    Last Post: 04-20-2012, 06:28 PM
  3. question on laminated wood for bowl
    By Drew Watson in forum General Woodturning Q&A
    Last Post: 11-16-2009, 08:24 PM
  4. Buffet-Mahogany and Sapele Ply-planning stages and first cuts
    Last Post: 03-19-2009, 03:43 AM
  5. Finishing stages
    By Doug Gatecliff in forum Finishing School
    Last Post: 01-04-2008, 10:48 PM
