Results 1 to 10 of 10
Thread: Bench plane blade sharpening/ Back bevels
    Central PA
    638
    I have a sargent 409 VBM (stanley #4 size) that I got a veritas blade and breaker for, it works great for smoothing most stuff but when I get into stuff where the grain changes I get tear out. This happens with the new blade as well as the old blade. How do you work woods like that. I know there are higher angle planes like the european infill smoothers and lie nielson has higher angle frogs for use with difficult woods. I think I have seen somewhere that you can put a 5 or 10 degree back bevel on the blade to change the effective angle, has anyone tried this and does it work?
    Bellingham
    2,449
    I can't comment on the back bevel as I have not done it myself. I have two smoothers, one with a normal angle frog and the other with a 50 degree frog. I believe that I do notice a difference with the higher angle frog, but I also believe that making sure my blade is truly sharp and that I take a fine cut is just as important. I get less tear-out now because I get better at sharpening. If you decide to go the back bevel route, I would be interested in hearing how it worked out for you.
    Bill is a lot better at this than I so I am really just agreeing here . The higher angle helps with tough grain issues. I use a bevel up smoother and have multiple irons, 25*, 38* and 50*, The 25* stays mostly in my low angle jack for end grain shooting and the smoother usually carries the 38* iron. I wouldn't want to push a 50* iron around all day but when I have reversing grain situations, its my cure to the problems that can arise.
    Sep 2007
    Plainwell, Michigan
    4,857
    Be sure to wax the bottom of the plane also to help it smoothly slide across the wood and help stop plane chatter
    5,321
    Pretty much what the others have said...
    Start with a 5° back bevel and take a very light cut.
    Spritzing a little water on the wood's surface will help minimize tearout.
    Making skew cuts (diagonal across the grain) sometimes helps, too.
    Central PA
    638
    Do you guys camber the blade or round the corners to keep from leaving plane tracks? And how much?
    5,321
    Quote Originally Posted by Dave Black View Post
    I just round off about 1/32" on each corner.
    Bellingham
    2,449
    Quote Originally Posted by Tom Niemi View Post
    A chunk of paraffin wax used in canning sits on my bench. For someone who does not normally believe in absolutes, one of tham I am leaning toward is; a sharp blade and a waxed sole solves most problems.
    Central PA
    638
    Is there any problems with finish sticking if I go straight to finishing after planing with a waxed sole
    Central NY State
    3,374
    Dave, I put a 10 degree back bevel on a Stanley iron in a Stanley #4, which I keep set up just for difficult grain. This effectively gives me a 55 degree frog. Bear in mind that the higher the angle, the harder the plane becomes to push. Skewing makes for an easier push, but also lowers the effective angle, and may increase tear out a bit. As Bill said, the sharper the better. As for the wax, I always wax my plane soles, and have never seen a problem with finishing.
  1. Jointer blade sharpening jig...
    By Brian Altop in forum Jigs and Fixtures
    Last Post: 04-05-2011, 01:33 AM
  2. Repurposed bench materials - dedicated sharpening bench
    By Darren Wright in forum Carpentry and Construction
    Last Post: 12-31-2010, 05:25 PM
  3. Bandsaw blade sharpening
    By Bob Anderson in forum General Woodworking Q&A
    Last Post: 12-29-2009, 11:05 AM
  4. Table Saw Blade sharpening
    By Darren Wright in forum General Woodworking Q&A
    Last Post: 04-12-2008, 02:05 PM
  5. Bandsaw Blade Sharpening?
    By Ed Nelson in forum General Woodworking Q&A
    Last Post: 01-12-2007, 05:38 PM
