Results 1 to 10 of 12
Thread: Craftsman Table Saw - Model 113.27520
    i need to replace the insert on my Craftsman table saw. it's an old saw, inherited from my dad. i need a zero clearance insert (ZCI) and i want to add a splitter (i already have the splitter - a nice little unit from Micro Jig). My problem - the current insert is pretty thin - around 1/8" aluminum. the replacements i've seen are thicker - so i need to know if i can either buy a thin one that will fit - or if i can router out the after market ones down to 1/8"
    I make all of my own out of plywood cut something to shape on the band saw then raise up the saw blade. Since you said it was thin I would to go to a hobby shop and get some plastic or poly to use. Oh and welcome to the forum.
    Craftsman Table Saw - replacement insert
    Thanks. i like the hobby shop idea - i'll give that a try. i'm concerned if i use plywood or some other wood and i router the edge down to 1/8", it won't hold up. i may be able to find a piece of plastic or some other material that'll work better.
    Dec 2008
    Portland, Oregon
    1,898
    We have a place here in town called "Tap Plastics" that sells plexiglas and other types of plastic. I get the white cutting board type plastic and use that. I made a master insert and use that with a flush cutting bit to clean up the inserts after roughing them out on the band saw. They have a scrap bin and sell it for $1.00/lb.
    Jesus was a Woodworker
    5,167
    Why not use thicker material and simply rabbet the edges so the plate sits into the throat, 'hanging' deeper into the opening than the original?
    I had a saw like that. I tried thin material (not metal) and had trouble with sagging and staying in place. Then I used 1/2" BB plywood and rabbeted it in.
    3,134
    My Dad used to use thin material & glue a stiffener on the under side.
    I used 1/2" thick material & rabbeted the edges all the way around & ran a groove where the blade went through the same depth as the edges. This gave clearance for the ZCI to set fully down into the table before the blade was rolled up through it. I have used good quality plywood as well as cutting board material I got at Ace Hardware I made several ZCI out of that material it cost around $3 per ZCI.
    13,356
    Thanks Bart for giving me the solution to a problem I've been thinking about.
    I bought some inserts for my saw when they were on sale, but I can't use them yet because when I put them on, they wont go down all the way due to the blade.
    I think I'll just mark the location of the blade on them and use my router table to take a little off so they can sit all the way down before I go ahead and raise the blade through them....
    5,318
    ...I bought some inserts for my saw when they were on sale, but I can't use them yet because when I put them on, they wont go down all the way due to the blade.
    Brent,
    Just put a blade from your circular saw in the TS, and raise that thru the insert, then change back to your regular 10" blade. One of the outside blades from your dado set will also work.
    13,356
    And an even easier idea... Thanks Jim!
    When I had a saw like that (3/32" thick actually) I would use 1/4" melamine or surplus Pergo bought on the cheap and route a rabbet around the shaped insert then glue a block of hardwood under where the MJ Splitter holes got drilled.
  1. Craftsman Verriable Speed Model 351.217150
    By John Ledrich in forum General Woodturning Q&A
    Last Post: 05-29-2013, 12:00 AM
  2. Craftsman Model 351.217150 Lathe's Variable speed control broke
    By Dimitri Schreiber in forum New Tools
    Last Post: 08-13-2010, 09:42 PM
  3. 1950's craftsman table saw Mod#113.27520
    By Ron Perry in forum Old Iron
    Last Post: 01-14-2010, 07:55 PM
  4. Craftsman Table Saw model# 113.299410 in Indiana
    By Tom Baugues in forum Old Ads
    Last Post: 08-17-2009, 09:22 PM
  5. Craftsman Professional Model Table Saw
    By Dan Mooney in forum New Tools
    Last Post: 01-11-2009, 05:09 PM
