View Poll Results: Does your Oneida cyclone filter get clogged prematurely?
Voters
18. You may not vote on this poll
  • yes
    0 0%
  • no
    18 100.00%
Results 1 to 10 of 20
Thread: Oneda Cyclone issues
    I have been using a 5 hp Oneida Cyclone for the pass year and a half. I average about 50 gallons of debris a week, mainly from milling, not sanding. Dust and debris is pulled up and swirls around the clear flexible tube from the 55 gallon drum when there is only about 12" of material in the bottom of the drum. This happens as soon as the cyclone is turned on. Also, the debris below the clear tube, in the barrel itself, constantly swirls. The air flow diminishes fairly rapidly (about 4 weeks) after the filter is taken down and thoroughly cleaned. I have called Oneida multiple times and the response I get is "this is new, we have never heard of this before". I have tested the outside of the cyclone, barrel, and flexible tubes for leaks, and have none. I have talked to other Oneida 5 hp Cyclone owners and heard similar issues. I recently talked with a shop owner who has a Torit/Donaldson Cyclone and he told me that this is not normal. Is this normal or just a design issue with this cyclone? Is there a way to stop the dust from being pulled up from the bin and prematurely plug the filter?
    2,784
    Are you sure it is getting to the filters? If it is only swirling at the pipe going into the debris container, that doesn't necessarily mean it is being sucked up into the center tube of the cyclone to get to the filters. Not sure how to check for that. If it is getting to the filters, that would lead me to believe that there is a leak somewhere that you haven't been able to detect, as that is the only cause I've ever heard reported that could suck the debris out of the container and into the filters. Doesn't mean I've heard all of the possibilities though. Keep on Oneida. Show them that there are others out there with this problem. Hopefully they will be able to help you diagnose and fix whatever is going on. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    Thomasville, GA
    6,000
    I have a 3HP SDG and I see some chips swirling in the clear tube, but that seems normal. I've never had anything but light dust getting to the filter. If you're sure there is dust and chips getting from the collection container back to the filter, it leads me to believe there is a leak at the tub. When the system is running, there is a vacuum on the tub just like the rest of the system.
    Bill Arnold
    Monroe, MI
    470
    Are you sure you don't have a leak somewhere in the drum? My Grizzly was wanting to suck the bags and dust into the filters until I added a bead of caulk where the two halves of the dual-size drum mated. Very small leak, but big impact.
    Thomasville, GA
    6,000
    Quote Originally Posted by Matt Meiser View Post
    ... My Grizzly was wanting to suck the bags and dust into the filters until I added a bead of caulk where the two halves of the dual-size drum mated. Very small leak, but big impact.
    There's so much vacuum on my drum that it will lift off the floor until it gets several pounds of chips/duct in it!
    Bill Arnold
    Do other brand cyclones do this ?
    Quote Originally Posted by Jim O'Dell View Post
    I am assuming that since it is pulling chips and dust out of the bin and swirling it around the clear tube that it is picking up the fine dust also. It is hard to imagine that if it is not picking up the fines from the bin then it must be serparating very poorly. I tried extending the clear tube to see if that helped, but not dice. I took the filter down 6 weeks ago and thoroughly cleaned it with a leaf blower from the inside. There is so much dust that cakes between the pleats that it has to be slightly broken up by hand in order to loosen it up. Does anyone know if the same thing happens on other cyclones like Clearvue or Grizzly's?
    When I put the fiber barrel bag on, it does lift it off the ground when it is empty. However, once I get about 6-8" of material in the smaller fiber barrel, and start the machine up, it sucks a small bit into the clear tube and slings it around. At this point the clear flexible tube vibrates pretty badly. However, if the drum is empty, and no material is picked up, then there is no vibration coming from the clear tube. I have checked for a leak with a smoke test, and did a garbage bag test by putting a large garbage bag around the outside of the barrel first, then the clear tube. I could not get the garbage bag to cling to in the slightest bit. If there is a leak between the cyclone body and top then that will be a real s.o.b. to fix. It will have to be taken apart and have new weatherstrip put in. This unit has only been in use for about 1.5 years or so. Do these things occur on other cyclones?
    Thomasville, GA
    6,000
    Quote Originally Posted by Tim Brun View Post
    ... Do these things occur on other cyclones?
    I've never had any issue with my 3hp SDG. Cleaning the filter takes a few light taps on the outside to knock the fines dust into the small bin; occasionally, I'll blow it from the outside with an air hose. The suction on all tools is great.
    Oneida has always been great to deal with on both the sales and customer service side. If I were you, I'd write up the issues as you have described them here and send an email to a tech.
    Bill Arnold
    Oct 2007
    N. Ga.
    15
    Sorry to hear about your problems with your dust collector. I was about to pull the trigger on a 5hp Oneida but now I will certainly look elsewhere. Anytime you have a major system fault (like you describe) and the vendor says "we've never seen that before" it's either a brand new design or an engineering / fabrication mistake. In your case the fact that you've been using the unit for a year and a half indicates it ain't a new design.
    Hope they get it fixed for you. Keep on them.
    2,784
    I'd get a stick of incense and burn with the unit running to see if it sucks the "smoke" into the unit anywhere below the bottom of the cone.
    Otherwise I can't help either. I do have a Clear Vue, but I exhaust outside, so no filters involved. And I use a plastic 55 gallon drum for my chip barrel, and it does not lift off the ground. Jim.
    Exclusively Irish!
  1. Cyclone Clog...?
    Last Post: 04-03-2016, 11:12 PM
  2. Sheep Cyclone
    Last Post: 02-06-2012, 04:53 PM
  3. cyclone
    By Jiggs Elphison in forum General Woodworking Q&A
    Last Post: 11-24-2009, 10:46 PM
  4. Building a cyclone to fit my needs
    By Alan Bienlein in forum General Woodworking Q&A
    Last Post: 07-14-2009, 12:56 AM
  5. Cyclone recomendations / which do you use
    By Dan L Clark in forum New Tools
    Last Post: 08-30-2008, 09:18 PM
Tags for this Thread
