Page 1 of 10 12345 ... LastLast
Results 1 to 10 of 97
Thread: A SketchUp Warm-Up Exercise
    SE Minnesota
    2,526
    Well, as a sort of prelude to some sort of SketchUp "bootcamp" which still needs to be figured out, let's have a little exercise. Everyone down on the floor and give 10 push pulls!
    Alright, so for our first exercise I've chosen Doug Stowe's little Friendship Box. I've given you all the dimensions you need to draw it. And lest someone should say there's missing dimensions, you're woodworkers. Figure it out. do what makes sense. Where's that master sergeant smilie?
    You get 10 minutes. Be honest.
    Go!
    Remember to save the SketchUp file. You're gonna need it again.
    17,471
    dave when i make a component, i cant seem to get it to show up like you showed me ,, i made the side of this and hit the component button but when i go back to select it its just seperate planes???
    SE Minnesota
    2,526
    Larry, I figured you'd be the first to go for this.
    Did you select all of the geometry of the side before hitting the Component button?
    17,471
    i took and used the arrow tool and done a drag select and then hit the component tool and named it.. but when i wanted to move it i couldnt..
    SE Minnesota
    2,526
    Hmmmm....
    I wonder if you missed selecting even one edge. If you do, when you go to create the component, you'll find that the box for "Replace Selection With component" is not ticked. The component gets made but it doesn't replace the geometry.
    This will be a good topic to cover in a "bootcamp".
    Save your file and send it off to me.
    17,471
    its to late i hadnt read the fine print dave so i pitched it wheni didnt get to where i needed to be maybe i will try again later today and if so will save it dave..
    Constantine, MI
    7,890
    OK, so it took me 1/2 hour.
Name:	1 (800 x 582).jpg
ID:	64660Click image for larger version.
Name:	2 (800 x 666).jpg
    www.wrworkshop.com
    SE Minnesota
    2,526
    Good work Rennie. Practice, practice, practice.
    Actually, folks, it doesn't really have to be a speed thing but you want to work on being efficient so you can get out to the shop and get to cutting real wood.
    5,169
    I'll try later. Just got back from R&R and need to catch up. And I work my 'regular' job tomorrow. Need to get ready. I AM looking forward to this. However, Dave, I recently got a MacBook and need to set up SketchUp preferences for myself again.
    Thomasville, GA
    5,992
    OK, Dave. Here's my go at it. It took a little over 20 minutes.
    Bill Arnold
  1. How to keep warm when its cold outside...:)
    By Rob Keeble in forum The Cook Shack
    Last Post: 11-03-2013, 06:06 PM
  2. Anyone Up For a New Homework Exercise? [SketchUp]
    Last Post: 03-22-2012, 03:36 AM
  3. SketchUp Drawing Exercise No. 2
    Last Post: 02-13-2012, 12:48 AM
  4. For those of you in a warm climate
    By ken werner in forum Off Topic Discussion
    Last Post: 03-09-2011, 02:01 AM
  5. Who Says SoCal is Always Warm?
    Last Post: 01-16-2007, 03:29 AM
