Results 1 to 10 of 18
Thread: Wood gone wonky – an idiot level question
    Mar 2010
    Maplewood, NJ
    78
    I'm trying to make some old-fashioned wood storm windows for my 1902 garage.
    I bought a couple of 6" 5/4 pine boards at Home Despot, made sure they were nice and straight in all directions, took them down to my shop and ripped a 2" piece off of one of them.
    That piece immediately skewed by about a 1/2" in two directions.
    What did I do wrong? I know it's not a moisture issue... the wood is quite dry.
    Did I just buy the wrong wood in the wrong place?
    Thanks!
    you didn't do anything wrong that wood just did what it wanted to do. they probubly dried it to fast or something like that. btw I have never seen 5/4 lumber at the borg.
    Mar 2010
    Maplewood, NJ
    78
    Thanks, Don. My problem now is that, should the rest of the wood behave in the same fashion, it's going to wind up being useless to me. Wooden frames meant to hold 26" X 27" panes of glass need to be flat.
    Would I be better off using different wood? Would it help to buy it at a lumber yard rather than a borg?
    And, yeah, it really was 5/4, a full 1 1/8" thick, which surprised me. I was expecting it to be a bit thinner.
    I never trust wood from the borg for anything other then simple framing so yes I would go to you local lumber supplier. Personally if it were me I get some poplar or something fiarly inexpensive and stable plus you'r just gonna paint it I assume.
    Southeast Pa
    2,019
    Brian
    I had written a fairly long post on this and hit the wrong key..
    But as Dons says there isn't much you can do with the wood at this time, and yes every piece will probably do the same thing. It is caused by what is called "case hardening" and it happens with cold rolled steel as well. When you remove the surfaces countering the internal tension it just goes wild. If you can find something air dried or at least dried slowly you have a chance..... This wood was ruined before it got to you. Some of the fast growth wood is hard to dry without internal stress...or so I have heard...
    Even plywood does it today which used to be unheard of...Look at the twists in the plywood piles at the borg....
    Find a local sawyer and good luck....
    Wood may well be cheaper as well...
    Garry
    Mar 2010
    Maplewood, NJ
    78
    Thanks guys. I'm out $32 for the wood, but maybe I can find a use for it that doesn't require ripping it, or where it won't matter if it warps. It's a comfort to know there's an alternate solution.
    Westphalia, Michigan
    955
    I think Don got it right. I would get some poplar And use it for the frames. Just be sure to prime and paint them with a good exterior grade paint. Sometimes you can luck out with pine 2x wood from a lumber yard. I have gotten southern yellow pine once that worked well for a similar project.
    However you must remember that the lumber buyers for the big yards and the borgs are buying in large quantities and from several different sources so you get "white wood" of various species, mostly pines or spruce trees. The sources are spotty at best in my opinion when it comes to drying the wood properly. Also a lot of the 2 x 4's are made from smaller trees that have lots of knots and stress in them. When I am planning a project like yours a I will sort through a lot of wood to get clear and straight boards. That is still no guarantee that they won't warp.
    I'm a certifiable tree hugger. (it's a poor mans way of determining DBH before cutting the tree down)
    10,606
    If you are going to paint the shutters HD has primed 5/4 6" wide stuff that is made up of a number of glued up pieces. I used it on my exterior window trim. No problems with it at all.
    17,475
    the glued up panels have taken out the stresses in the parent wood therefore making a good choice for your work..brian
    Jan 2011
    Hudson Valley NY
    122
    Brian, I just finished the 33rd storm window, 13 more to go, for a historical site nearby. I bought all my 5/4 from lowes and have not had a problem other than a knot spliting out when I put a screw through it. Maybe a bad batch at hd?
  1. IDIOT SIGHTING
    Last Post: 03-08-2010, 03:46 AM
  2. Graphics still wonky
    By Bruce Page in forum Site Questions and Test Posts
    Last Post: 12-14-2007, 08:12 PM
  3. Idiot question
    By Billy Burt in forum New Tools
    Last Post: 09-24-2007, 05:50 PM
  4. Wonky.....
    Last Post: 08-08-2007, 12:00 PM
  5. Elec. Question - Wiring DC Bin Level Sensor to Alarm Light
    By Doug Shepard in forum General Woodworking Q&A
    Last Post: 11-24-2006, 03:59 PM
