Results 1 to 8 of 8
Thread: New finish over old
    New finish over old
    I have some birch veneer surfaces that were varathaned several years ago. They only got one coat before life got in the way. What special steps do I have to take, besides a light sanding, to prepare them for the extra coats of varathane they should have gotten (insert "guilty" smiley here). Or is it too late? Thanks!
    London, Ontario
    3,383
    I'd first give them a good washing, before a scuff sand. But that is all I'd do, Susan.
    5,320
    I'd wipe/wash with naphtha or paint thinner first - to remove any dirt, grease or waxes - then sand lightly (220 or even 320 will do).
    Apply at least two more coats of the Varathane, sanding between coats with 220 or 320 to remove any imperfections. After the final coat has dried for about a week, go over it lightly with 4-0 steel wool or gray ScotchbriteŽ pads, then wax it.
    17,472
    yup what jim and art said
    Apr 2009
    Outside the beltway
    5,253
    yep what he said
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    May 2011
    So. Florida
    268
    I would do a wipe down with mineral spirits or naptha as suggested. Keep in mind the overall sheen you are after, i.e., gloss, or satin/semi gloss. I would lightly sand with 320x with an open coat sandpaper, not garnet or aluminum oxide. I would use a silicon carbide paper intended for dry use (light gray), that's called "No-Fil", or "Fre-Cut".
    After application of topcoating, the finish will have a certain sheen from being wiped on or brushed. Any rubing on that finish will change the way it looks, so experiment with a sample. If it needs rubbing, I wouldn't use steel wool, but rather a synthetic microfiber pad, like a white ScotchBrite pad (very smooth). Allow each application to thoroughly dry before adding another topcoat.
    You have all been most helpful! My house and I thank you
    May 2009
    Poway, CA, near San Diego
    174
    Hi folks,
    If it's the same can of finish from several years ago, you might want to test it to make sure it still drys OK.
    Bob
  1. What finish?
    By Kenny Wright in forum Finishing School
    Last Post: 02-24-2010, 02:00 AM
  2. Replies: 1
  3. Finish for bar top?
    By Shane Ricciardi in forum Finishing School
    Last Post: 12-02-2007, 10:38 PM
  4. Finish that won't dry
    By Gene Miller in forum Finishing School
    Last Post: 10-15-2007, 09:43 PM
  5. To finish or not to finish - That's the question!
    By Bruce Shiverdecker in forum General Woodturning Q&A
    Last Post: 01-10-2007, 04:22 AM
