larry merlau
- Delton, Michigan
there has to be a way you can group select and revers face to do the dovetails on the other end.. and i would think you could do a multiple push pull as well.
Here's mine, I found the colors
you didnt even listen in on the class and yur still on top of it
Who threw that spitball!?
Thanks, Don. I'll try later. What's this about multiple push/pulls?
That was me I was trying to get your attention....is there a way to shrink the file to the acceptable upload level? Mine came out a hair larger than allowed
Edit: I also saved the file with the colors added...any way to remove them?
The first thing I would do is go to Window>Model Info>Statistics and click on Purge Unused. Save the file and see if you can upload it. I don't know what the forum's file size limit is for SKP files.
To get rid of the materials, go to Window>Materials. Click on the house icon to go to the In Model library. Right click on the material thumbnails and choose Delete. Repeat for each material but purge unused first to get rid of any materials you weren't using anyway.
Got it! Thank you Dave!!! my original file was something like 169 kb, 150kb is the set limit I believe
