- Reno NV
Best way to get it? Water! If you have a pond in there, the water will absorb the daytime heat and release it at night. You probably won't even need a heater, if the house is well sealed.
Dig down a couple feet, build a frame one foot above ground. I use stacked two by fours, staple the plastic to the top of the frame *after* it's fill with water, and finish it with 1x2s nailed into the frame. Line it with six mil black plastic from the borg. Make it fit across the back, and about 2 feet wide. An 8x2x3 foot pond will be enough. You can build a greenhouse bench over it. Put a cheap aquarium bubbler in there to recirculate the water.
Got any pictures Bill? I'm picturing a trench along the back side that goes down into the ground and comes up about a foot above?
That might be doable...
