Results 1 to 10 of 11
Thread: follow me exercise
    follow me exercise
    Just playing around with sketchup and learning the follow me tool.
Name:	follow me exercise.jpg
    Thomasville, GA
    5,997
    Looking good, Don.
    I'm finding that Follow Me is a great tool for many things. This is a fairly simple item, but I needed it to add to a bathroom and closet remodel I'm planning.
    I used Follow Me to make an individual wire for a shelf assembly by having a small circle follow two edges of a rectangle.
    Another thing Dave demonstrated was using a multiplier with Move/Copy. I took one of the wires, used Move/Copy to space it over 1", then typed *69 to make a total of 70 to fill the length I needed.
    Bill Arnold
    Looking good, Don.
    That is cool I was just now messing with the multi copy tool
    17,472
    this is as close as i am gonna get to lathe,,,
    Not bad Larry
    Thomasville, GA
    5,997
    Larry, you did good on your spinny thingy!
    Don, I practiced with the Move/Copy multiply and divide function also (still practicing). When I did the dovetails, I drew the top tail, used it to Move/Copy to the bottom tail position, then typed /2 to add the center tail exactly in the middle. I think I'm going to like that functionality!
    Bill Arnold
    hmmm something new to play with
    17,472
    simple table with double bevel.. now when you done the move in /2 bill that put it in the middle? also you had to do that agin on the opposite side right,, looking at the same face..
Name:	table w-double bevel.jpg
    shoot Larry your making it look easy
    Thomasville, GA
    5,997
    ... now when you done the move in /2 bill that put it in the middle? also you had to do that agin on the opposite side right,, looking at the same face..
    I made the tails and pins on one corner, then turned the box and repeated on the other end of the end piece. To save some time, I then deleted the end with the hole in it and copied the end with the pins into that position. With the pins showing through on both of those corners, it was easy to use them as a pattern to draw lines, then push the 'waste' away from the tails. To complete the assembly, I put the lid back in place (after moving the nut and pin) so I could drill a new hole.
    By the way, you did good on your table!
    Bill Arnold
  1. an exercise in futility
    By allen levine in forum Finishing School
    Last Post: 06-20-2015, 06:00 PM
  2. More exercise
    By Roger Newby in forum Off Topic Discussion
    Last Post: 05-26-2010, 02:45 PM
  3. EXERCISE FOR PEOPLE OVER 50
    By Bart Leetch in forum Off Topic Discussion
    Last Post: 05-26-2010, 01:42 AM
  4. An exercise in neander
    By Stu Gillard in forum Handtool Project Showcase
    Last Post: 02-16-2009, 12:41 PM
  5. getting exercise
    Last Post: 03-26-2008, 08:56 PM
