Oil based stain and water based poly?
As I understand things, they will work if you put a coat or two of dewaxed shellac between the stain and the clear coat.
Yep! What Vaughn said.
You might get lucky and be able to use the WB straight over the OB stain, if you let the stain dry/cure for a couple weeks, but I'd use the shellac anyway. Zinnzer Sealcoat® works great for that.
I'm in the same dilemma. I checked with General Finishes and they said let the stain cure for a minimum of 72 hours. I'm going to give it 6 days because I can't get to it till this weekend.
