Results 1 to 10 of 14
Thread: Convert DWG to SKP?
    Thomasville, GA
    5,769
    Question Convert DWG to SKP?
    I've done some research on this and find that SU v7.1 had this capability but v8 does not. Is there a utility that provides for converting dwg/dxf files to skp?
    Thanks.
    Bill Arnold
    NRA Life Member
    Member of Mensa
    Live every day like it's your last, but don't forget to stop and smell the roses.
    SE Minnesota
    2,499
    There is a plugin which is said to import DXF to SKP but I haven't used it so I don't know how well it works. I haven't seen any importers for DWG files. As I recall, I think there's some licensing issue thing with DWG files. Google has to pay for licensing the importer and so they only make it available to those who pay for the program. There's a free 2D CAD program that can export SKP files. I have it on my computer at home but can't recall the name of it. I'll look when I get home and report.
    Thomasville, GA
    5,769
    Some of the items I'm using in a remodel drawing are available in those formats. It'll probably be easier to draw up an approximation for my purposes, though.
    Bill Arnold
    NRA Life Member
    Member of Mensa
    SE Minnesota
    2,499
    Very often the CAD files I import into SketchUp require so much clean up to be usable, it's usually easier to just draw it from scratch. This is especially true with 3D CAD files but 2D ones are often as bad. The thing with 2D DXF/DWG files is that lines don't have to intersect as they must in SketchUp. In order to get faces in SketchUp from the imported file you have to go poking around to find the gaps. And even if there are no gaps (I've never seen a CAD file like that, BTW) you still have to do something after importing to get the faces.
    Southeast Pa
    2,015
    Bill
    One good thing about sketchp is multiple versions can easily be installed..
    And though the DXF plug in for version 7 was gone for a while I managed to track it down.....
    There are also a couple of free ones mentioned that you have probably found.. From what Dave and others say they are of limited usefulness.
    Garry
    Thomasville, GA
    5,769
    Installing multiple versions of SU isn't something I want to do just to gain some functionality that is questionable. Besides, having to draw a handful of items will give me more experience with SU!
    Bill Arnold
    NRA Life Member
    Member of Mensa
    SE Minnesota
    2,499
    There you go, bill. Good way to look at it. Besides, it won't be long and you'll be wanting the LayOut side so you'll buy the pro version anyway.
    Thomasville, GA
    5,769
    Quote Originally Posted by Dave Richards View Post
    I'd be a whole lot more tempted, if it were half the price!
    Bill Arnold
    NRA Life Member
    Member of Mensa
    SE Minnesota
    2,499
    Compare its price to a seat of AutoCAD or better, SolidWorks. I just looked up AutoCAD. It comes in at about $4K. SolidWorks didn't seem to show pricing but last I look a full seat was somewhere close to 10K
    Thomasville, GA
    5,769
    I know SU pro is a bargain for what it does. I've got a whole lot more to learn first. Remember, a little over a month ago I didn't even want to try to start on SU again because of previous failed attempts. Something was right about the timing or the phase of the moon this time around!
    Bill Arnold
    NRA Life Member
    Member of Mensa
  1. I might have a convert on my hands
    Last Post: 05-31-2016, 06:36 AM
  2. Convert 1 Phase 1 HP Motor to Variable Speed ?
    Last Post: 04-30-2014, 03:06 PM
  3. LED Convert Here
    By Leo Voisine in forum Off Topic Discussion
    Last Post: 03-03-2014, 11:27 PM
