Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: 30 hours working on a hickory bow -then crack -UPDATE
    Toronto, Ontario, CANADA
    2,332
    Unhappy 30 hours working on a hickory bow -then crack -UPDATE
    Yesterday afternoon, I was in the final stages of completing a hickory bow. The stage that I was at is called tillering. Tillering is an iterative activity where stretches the bow using a tiller board, then removes the bow and removes a bit of material off the front surface with a cabinet scraper, then stretches the bow again, then removes some more material, etc. etc.Here is a photo of my bow being tillered:Click image for larger version.
Name:	hickory bow being bent using a tiller board.JPG
ID:	65088Here it is being scraped:Click image for larger version.
Name:	Hickory bow being scraped.JPG
ID:	65089About 15 minutes after that photo was taken and a couple of iterations later, as I was pulling the string down into another notch on the tiller board, there was a dreaded CRACK sound then silence. A spot on the back surface of the bow had come apart:Click image for larger version.
Name:	Hickory bow with cracked surface area.JPG
ID:	65090The cracked material is on the surface and not all the way through but that has destroyed the integrity of the growth rings that dictate the shape of the bow and the bow is useless. It cannot be repaired. I am unhappy and my grandson Ethan, who helped me work on the bow in some of the earlier stages, is going to be even more unhappy when I tell him after I pick him up at school this afternoon.
    Cheers, Frank
    17,475
    there are other woods that are more suited to making bows frank. osage is one of the better ones. and maple works to
    Central NY State
    3,374
    Bummer Frank. The craftsmanship of risk rises again, to laugh at us.
    2,332
    Larry, here in Canada, hickory seems to be the favoured wood. I was told by the fellow who taught me how to make a bow that hickory is good but that both yew and osage are better. In his opinion, hickory is better than maple and is the best local wood for the job.
    Yew and asage do not grow in Canada, hickory does and my stave came from an Ontario farmer's bush lot. Other staves from the same tree have worked well for other people.
    I am attaching a photo of another hickory stave that I have in my shed and will use some day (after I recover).
Name:	Making a bow 01 -An almost finished hickory bow beside a hickory stave -small.jpg
    Cheers, Frank
    That's really too bad, it always hurts to lose all that time and effort. Maybe a silver lining can be a lesson of determination and resolve to not quit? It's a bummer though...
    12,264
    Sorry to hear this Frank. I know Exotic woods out in Burlington had some yew staves at one time.
    17,475
    i know that the tillering is where it happens the most and usually right at the end where you need just alittle more.. you make more than one to get one almost always..
    9,077
    Endeavor to persevere Frank. Bummer on the setback. Good practice for the next one . . . that was an attempt at a "silver lining" sort of thing.
    13,363
    That's got to be frustrating...
    Can't wait to see the next one completed!
    10,604
    That just plain stinks
  1. Crack filling question
    Last Post: 02-28-2013, 09:52 AM
  2. Repairing a Crack in a Guitar Top
    By Dan Mooney in forum General Woodworking Q&A
    Last Post: 11-09-2012, 06:19 PM
  3. Another crack thread
    Last Post: 03-21-2009, 04:40 PM
  4. PM Messaging system !!!Update Seems to be working now!!
    By Rob Keeble in forum Site Questions and Test Posts
    Last Post: 03-03-2009, 08:28 PM
  5. Fix for a crack
    By Tony Falotico in forum General Woodturning Q&A
    Last Post: 07-30-2007, 07:09 PM
