Results 1 to 10 of 16
Thread: Help with a Grizzly saw and Excalibur dust collector
    Oct 2011
    Cortland NY
    238
    I have both in our shop. However we have to have a separate splitter mounted to the saw with kick backs. I have had this saw setup since 2010 and it has worked correctly. The problem and the help I need is that the guys in the shop have lost the splitter/anti kickback that makes the saw OSHA compliant. I have a walk through scheduled at the owners request for April and need to find a replacement by then. I have checked a number of places and all my records back for that time and can't seem to find the PO that I ordered it from. I called Grizzly directly and they do not have anything they offer so I had to order it else where. If any of you have had to go through this and can help me locate what I need I would be grateful. Even if I have to by the everything new for the splitter and it's mounting hardware I will. Otherwise this saw must be locked out and kept unusable until either we get it corrected or replaced. I hate to get rid of the saw for just that.
    The saw model was a G1023S if that helps. Sure could use some help.
    17,470
    check out the merlin splitter it might work for your application.. if you could show us a picture of what you had or are needing to fit ot alter that would be helpful..
    Los Angeles, CA
    2,667
    Not sure if this will work for you. It is mounted on the ZCI.
    http://www.microjig.com/products/mj-...er/index.shtml
    or a bolt-on riving knife like this
    http://theborkstore.com/main.sc
    Oct 2011
    Cortland NY
    238
    Thanks guys. I went to the sites you posted and I found that I ordered it from the BORK store site. Thanks guys again now I can get things going.
    17,470
    Quote Originally Posted by ed sautter View Post
    just outof curiosty ed,, which one did you use and how did you like it for every day use? do you run dust collection at the TSaw blade area?
    Oct 2011
    Cortland NY
    238
    The one we bought from the BORK store was for the Grizzly saw we have. It was made directly for it. I remember being impressed that it was cast and well made. The spitter was also high quality. However you had to open things up to remove it but install was just push in and go. It would be nice to have it some where to hang it wne not used. As to the Excalibur well that's another story. Great concept and does work well at covering our a** for OSHA but as to it being what it was to do well two things. We have the Euro vac system for all bench tools and that was how the mounted the dust collection to the saw. It just isn't enough to truly do any good. I have a much larger collector for the CNC, panel saw and v-grover that I ought to have had this saw connected to. It would then have been sonething much bette. It mounts to the saw well and does extend out to a much longer reach. Well made guard and is able to be out into the float position or a raised position. So that's good. But are there better ones yes. But for the cost this serves the pourpose. OSHA requires the blade be covered. This cover could stand 6" above the blade if you wanted and you would still be covered. It's the ability to not be in direct contact with the blade that is what they are looking for. As you all know that is next to imopssible with many cuts on the saw unless you are ripping. The other requirement is it have anti kickback and a splitting knife. That's why Grizzly discontinued the model saw we got at such a deal. Go figure they knew as well. Hope that's what you were looking for Larry.
    17,470
    yup thanks ed
    I'm confused as to why Grizzly couldn't sell you parts for a current model saw(?).
    Glenn...I think he's using an aftermarket overhead dust collection and blade guard and the OEM splitter won't work.
    Ken
    Oct 2011
    Cortland NY
    238
    Ken you're right it's after market and Grizzly didn't offer this back them it's a 2009 model year saw.
    Here's an update. I talked to the guy from the BORK Store and he sent pictures of what he had to confirm it with what I have. They are not the same. I will have to continue my search. I'd like to get the correct part that is missing but I fear that that will be a challenge as I can't find the manufacture. I do believe I purchased the Excaliber from someone in PA but am not bring anything up just yet. I willhave to take off the parts on the saw and see if anything is there on it that will help. Keep you all posted.
  1. Dust Deputy vs. HF Dust Collector
    Last Post: 06-29-2015, 01:54 PM
  2. When does one really need a Dust Collector?
    Last Post: 06-17-2013, 06:30 PM
  3. Grizzly Dust Collector Problems
    By Jeb Taylor in forum New Tools
    Last Post: 08-21-2011, 02:54 AM
  4. HF 2 hp Dust collector
    By Garry Foster in forum Hot Deals
    Last Post: 03-04-2011, 06:36 PM
  5. Grizzly G0583-Cannister Dust Collector w/remote
    By Scott Custer in forum Old Ads
    Last Post: 03-09-2008, 05:34 AM
