Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: a cradle idea i've been working on
    Dec 2008
    falcon heights, minnesota
    5,609
    about a week or so ago, my wife asked me if i would build a cradle for one of her friends from church who was expecting in about 7 months. like a good husband , i said ok, i would work on a design for them, but, will hold off on the build, to make sure everything is still ok. so, with that i set to work on sketchup , and here iit is. it's sort of my version of greene & greene of a sort. i did omit a couple of things, such as the pivot pins, locking pin to keep it from rocking, and the keys for the stretcher, i'm holding off on those.
    Attached Thumbnails Attached Thumbnails cradle a.jpg   cradle b.jpg   cradle measured.jpg
    benedictione omnes bene
    www.burroviejowoodworking.com
    17,470
    needs to be tapered on the ends so the bottom is narrower than the top.. it looks to boxey now..
    I agree with Larry and the sides are to high shorten it up about 6 inches. Your not gonna have to worry about the little one climbing out cause by the time he/she is big enough to do that their gonna be in a bigger crib.
    Oliver Springs, TN
    1,726
    Dan, I agree with the above statements. I also want to say that will be one sweet cradle! I hope you build it and I also hope you let us follow along.
    Dec 2008
    5,609
    i was thinking about tapering it to begin with, but the standard size of cradle mattresses are 18" x 36", and tapering it out from there, the top would be about 24" wide or better. so i stuck with the sides the way they are. i learned my lesson about mattresses, when i built a cradle for the youngest nephew, from some plans in an issue of today's woodworker, and had to have the mattress custom made to fit, and that cost quite a bit. the actual sides themselves are only 20" at the widest, and 18" where it drops down. it does look a bit big at first, that's why i included one with the measurements with the others.
    SE Minnesota
    2,524
    I would agree with the others. I also think the feet should be slightly narrower and about 2/3 thicker than you've drawn them. I would be inclined to use square pads for the bottom-most layer so it sits up a little bit. You might also consider tapering them slightly toward their ends.
    Quote Originally Posted by Dan Noren View Post
    So at least it wouldn't look like a box
    Dec 2008
    5,609
    ok, here's the mk 2 version. i used a minimum 10 degree angle to the sides, and i had to make the ends much wider to accommodate the 18" wide mattress. if i hadn't, the mattress would have been about 3" from the top. i added the 3/4" pads to the bottoms of the feet. they were already 1.5" thick to begin with, now up to 2.25". the width of the top has grown from a little over 19" wide, to 25 5/8" wide.
    heading in the right direction but still to tall on the sides. cut them down by about six inches and let other on hear see how it looks.
    Dec 2008
    5,609
    that's not doable don, as the lowest part of the sides is only a touch over 13" from the board for the bottom. add in the couple of inches for the mattress, and there is only 5" on the sides. then again, the ends would have to be reworked as well, and that wouldn't work out too good either. i'm working around a 18x36 mattress.
  1. Cradle build
    By Roger Tulk in forum Flatwork Project Showcase
    Last Post: 10-21-2013, 03:14 PM
  2. wine bottle holder idea i'm working on
    Last Post: 10-21-2012, 12:36 AM
  3. cradle build
    Last Post: 06-18-2012, 01:14 AM
  4. Cradle Project
    By John French in forum Flatwork Project Showcase
    Last Post: 05-19-2012, 04:12 PM
  5. Toy cradle
    By Matt Ducar in forum Flatwork Project Showcase
    Last Post: 04-27-2011, 03:51 AM
