Results 1 to 4 of 4
Thread: A great tool for handing hard-to-remove vinyl tiles -Festool Scraper
    Toronto, Ontario, CANADA
    2,332
    This week I am installing new tiles in the main bathroom in our house. I installed the old tiles about 25 years ago and used construction cement. Boy, do they stick! I guess that 25 years ago, I thought they would be on the floor forever.
    Here is a photo of the tiles being removed very slowly: Click image for larger version.
Name:	New tiles in bathroom 01 -The old tiles are going to be hard to remove -small.JPG
    After about an hour and a half of this, I remembered the scraper attachment (491 199) that fits onto my Festool LS 130 Duplex linear sander (567 777). That tool did a great job:
Name:	New tiles in bathroom 02 -This gizmo attached to my Festool linear sander makes thje job much ea.JPG
    and was about 5 times as fast as the method that I had been using.
    Here is a close-up of the tool with the attachment: Click image for larger version.
Name:	New tiles in bathroom 03 -Close-up of the Festool Duplex linear sander equiped with the scraper .JPG
    Cheers, Frank
    5,320
    I don't have that particular Festool, Frank, but I do know that a good power scraper makes a world of difference in removing tile like those. I re-did a kitchen floor a few years back, and -like you - discovered the Fein Multi-tool scraper after experiencing frustration at the 'manual' methods. The Fein, with scraper blade, made those tiles come up much easier. The Festool scraper looks wider than the Fein's, so it ought to make the job even faster.
    17,471
    now you need to use some sand paper to fix the gouges you show there frank, unless your going to use some floor leveler first..before the new floor goes down.
    2,332
    Larry, I thought about filling in the gouges with auto-body filler then sanding. I know that would work, but I decided to nail down a layer of thin plywood.
    So, I guess that I could just have nailed the plywood over the old tiles -oh well
    Cheers, Frank
  1. stabilized wood is hard, hard, hard
    Last Post: 12-16-2014, 04:12 PM
  2. Difference Between a Bowl Scraper and a Shear Scraper
    Last Post: 06-19-2012, 05:02 AM
  3. Scraper Sharpening some tips from Czech Tool
    By Rob Keeble in forum Neander Tool Questions and Show & Tell
    Last Post: 07-05-2011, 10:39 PM
  4. An alternative Festool systainer tool organizer
    By Frank Pellow in forum Jigs and Fixtures
    Last Post: 01-24-2009, 01:39 AM
  5. Removing old floor tiles (Festool comes to the rescue)
    By Frank Pellow in forum Carpentry and Construction
    Last Post: 03-06-2007, 02:58 AM
