Results 1 to 10 of 12
Thread: It Just Needed It....
    15,806
    The top of my workbench was getting a big funky, I've been working on too many non-woodworking things, fixing my trailer, fixing bicycles etc, so tonight I dug out the hand planes and had a go....
    I used my #4 1/2 to go across and diagonally first then....
    ... the #7 to go lengthwise, followed by the #4 1/2 again to make it nice and smooth.
    Lastly a new coat of Watco Natural Oil....
    ... almost good as new!
    Now back to work on that darn humidor!!
    Los Angeles, CA
    2,667
    Looks good as new.
    Yorktown, Virginia
    5,002
    Stu, that really cleaned up nice, but I'm too lazy for that. I keep a piece of red rosin paper (the kind roofers use) on my bench at all times and change it out when it gets too funky.
    Central NY State
    3,374
    Looks great Stu.
    Oct 2007
    Nova Scotia, 45N 64W
    1,243
    Like new, but with character!
    Stu, why didn't you put your end vice on the other corner, so it would work on the "front" of the bench? Schwarz seems to suggest that, but I'm sure you had a good reason.
    NH
    4,003
    Is there a name for the joint you used for the legs to top connection?
    Stupid hurts.
    15,806
    Quote Originally Posted by Peter Rideout View Post
    The leg vice works on the front of the bench, the face vice I put on the end, so I can use it like an end vice, I can use the dog holes on the table and the vice to hold stuff length wise on the bench.
    If I ever build another one (never say never!!) I'll invest in a wagon wheel vice, they are very cool!
    15,806
    The CoC prevents me from telling you what I called it while making it
    I guess it would be a combo through tenon and through dovetail joint.
    If I ever make another I'll cut the wooden beam in half so I can cut those joints with the skill saw, then glue the two halves back together, much easier.
    Jun 2007
    4,944
    No matter how you get there---A good bench is a wonderful thing!!!
    You did a great job.
    Now Enjoy,
    JimB
    VOTING MEMBER
    15,806
    Yep, and I enjoy it every time I use it, and I wonder how I ever got by without a good bench
  1. Is a radial arm saw needed?
    By Charles Jackson III in forum Old Iron
    Last Post: 08-13-2013, 08:27 AM
  2. Electrical help needed!!!
    By Bill Lantry in forum Off Topic Discussion
    Last Post: 08-14-2011, 03:12 AM
  3. ford fix needed!!!!
    Last Post: 11-20-2009, 11:25 PM
  4. Translation needed
    By Pete MoncrieffJury in forum General Woodturning Q&A
    Last Post: 10-13-2009, 10:09 PM
  5. help needed
    By john e duck in forum Jigs and Fixtures
    Last Post: 05-30-2008, 04:53 AM
