Page 1 of 5 12345 LastLast
Results 1 to 10 of 49
Thread: my new radial arm saw
    Feb 2012
    central florida
    208
ID:	65450Click image for larger version.
ID:	65451Click image for larger version.
ID:	65452Click image for larger version.
    Well here it is. it is a beast. probably one of the dumber purchases of my life but who's to say. also shown is my 10hp rotary phase converter. they don't build them like this any more. it has a 1/2hp dayton starter motor and 10hp westinghouse motor for the phase conversion
    I ended up paying $340 for the saw delivered and $200 for the phase convertor . The saw cost the the guy who delivered it $150 at the auction. Its an auction I almost went to but it was over 4 hours away so I ended up with what I would have been bidding on any way and i didn't have to drive. so thats a bonus.
    Much to my disappointment, 3 of the carbide teeth on my 20" blade are broken. Everything else seems to be in great shape.
    From what i can tell I will easily be able to do a 30" cross cut. probably more. the motor head seems to slide nice and smooth. the 90deg stop has a lot of play in it but I don't have to use the stop. I can lock it down to any angle I want and when its locked it is LOCKED TIGHT. The height mechanism works surprisingly well. Can't wait to get it running. If I only knew how.
    It is a little big for my shop, and I do feel kinda insane for wanting this but I figure if I get it all hooked up correctly The combination of the saw and converter together should be at least double what I paid for them. The down side is I am trusting all parties that everything works.
    well first of all congrats I guess, now let me ask you how much do you know about electricity and specifically how much do you know about 3 phase electricity. The box above the starter motor looks to be a magnetic starter. It appears to be wired into the line plug so I would assume it is to start the phase converter. If so you will need an additional mag starter and fuse protection between the phase converter and the saw.
    Congrats, Keith. That is indeed a beast.
    ...If so you will need an additional mag starter and fuse protection between the phase converter and the saw.
    I'm not certain, but it looks like there's a magnetic switch built into the end of the saw arm.
    Constantine, MI
    7,891
    Indeed it is!
    www.wrworkshop.com
    Unless it is built into the arm but that looks like a push button for starting activating the starter but typically a mag start would be a box containing the contactor and also the motor overloads. It would be to big to fit in the arm. a 7 1/2 hp motor at 230 Volts requires a size 1 starter which typically would be to big to fit in the arm. It might be mounted on the machine and not shown.
    Keith in studying your picture I have a few observations. In the third picture the outer insulation appears to have either been pulled out of the strain relief that was there to protect the wires or has worn through. This is a danger since nor the current carrying conductors are out where the insulation can be damged which as a minimum will cause them to short out and trip a breaker but could ground out and cause a shock hazard.
    In the last picture it appears from looking at it the starter for the rotory converter is on the upper left above the starter motor. You will notice a small white plug in module with a knob on top to the right of the contactor. This is a timer that is used to switch the starter motor off once the converter is up and running. If I were to guess I would guess that the box on the right contains some electrolytic capacitors. For safety sake put a cover over the starter. You can make one out of plexi-glass. I hope this helps.
    17,475
    that is definitely one large RAS... congrats and be sure to check this for safty issues before you go for the starter switch..
    Los Angeles, CA
    2,668
    Wow! that is one tiny power drill. Oh wait, it is sitting next to the incredible Hulk.
    Congrats!
    Feb 2012
    central florida
    208
    The loose insulation you appears to be more of a flexible conduit than just insulation. it looks as though there is a piece it slides into but I haven't checked it out to closely yet. I had no idea what that little dial was for. I am guessing the cover that is missing had a hole the little dial would stick out of so it could be adjusted. Thanks for cluing me in. I will definitely build a cover for it when its all hooked up.
    There is a big starter switch in a heavy steel box attached to the frame. the guy who owned it thought it was a phase converter but I was pretty certain it wasn't. Now that I took the cover off the box I see I was correct. it looks like a larger version of the one seen in the phase converter picture. I need to pick up a new volt meter and test the legs of the phase converter and get this puppy running.
    Like everyone, I sure wish I had more time.
    On a positive note. My wife says she has decided not to divorce me after buying what is obviously a very frivolous machine. I would like to think that when she sees me make my first 30" cross cut she will change her mind on the saws usefulness but I doubt it.
    Feb 2012
    central florida
    208
    Quote Originally Posted by Mohammad Madha View Post
    Congrats!
    Good one We are still laughing.
  1. Radial Arm Saw
    By Jeb Taylor in forum New Tools
    Last Post: 09-09-2011, 01:58 PM
  2. Radial Arm Saw ????
    By Tony Bilello in forum General Woodworking Q&A
    Last Post: 02-07-2011, 01:31 AM
  3. radial arm saw
    By Carol Reed in forum New Tools
    Last Post: 10-24-2010, 09:32 PM
  4. My new Radial Arm Saw
    By Brent Dowell in forum Old Iron
    Last Post: 02-26-2010, 06:26 PM
  5. Radial arm saw
    By Les Hoste in forum Old Iron
    Last Post: 09-27-2007, 01:39 PM
