Results 1 to 5 of 5
Thread: Chucks Apple
    Southeast Pa
    2,019
    Chucks Apple
    Well I finally found time to turn another pen. I chose the American Flat top for which I had two kits for but had never made one. For wood I used some Apple from Chuck and the pen blank swap. It was a beautiful piece of wood and had a great tight knot that I just knew would shine. Well I get ready to turn it and find I need new bushings as well as a new mandrel as no one seemed to make bushings to fit my mandrels. So I says lets try that between center turning. So made myself a couple sets of bushings one for the small end and another set for the larger end. I made the first set from a piece of rod from an old shock absorber and that wasn't a great decision either as that steel is tough and hardened. The next set I made from some new leaded steel stock and that was much better decision.
    Then I picked which part of the blank for each end and I thought the tight knot would be great for down near the tip. Again bad decision as if I would have used it for the clip end it would have stayed together, while as it was after I finished turning and was sanding it broke through, So I struggled on with super glue and saw dust.
    It looks ok but doesn't really do the blank Chuck provided justice. However I did learn a bunch. My Sketchup home work suffered as I have also been helping a friend with a trailer and construction project as well as trying to exercise 30-40 minutes a day..
    Here are the pictures and any advice or criticism accepted. I put the bushings I turned in the picture.
ID:	65559Click image for larger version.
    30,002
    Sounds like quite a learning experience, but from the looks of the photos, I'd say you did a good job of saving things.
    Jun 2007
    4,944
    I'm with Vaughn. If that's "saving things," what does the good stuff look like?
    Enjoy,
    JimB
    VOTING MEMBER
    Aug 2008
    Reno, Nv
    3,632
    Between the centers is the only way to go...your results prove it!
    Southeast Pa
    2,019
    Well I gave this one away yesterday and I must say the receiver sure was excited. I just hope it lasts what with the problems I had making it.
  1. CHUCKS DANG NEAR 50
    By Tom Niemi in forum Off Topic Discussion
    Last Post: 11-12-2012, 04:10 AM
  2. Grizzly Chucks
    By Chuck Ellis in forum Turning Tool Questions and Show & Tell
    Last Post: 11-02-2011, 03:24 AM
  3. Questions on Chucks
    By Rob Keeble in forum Turning Tool Questions and Show & Tell
    Last Post: 06-18-2009, 03:05 PM
  4. New Vacuum Chucks
    Last Post: 03-28-2008, 09:23 PM
