Results 1 to 10 of 29
Thread: Wood choice made - what do you know about Brazillian Cherry?
    Constantine, MI
    7,891
    My youngest daughter got married nearly 3 years ago an I promised her a piece of furniture as a gift. She hemmed and hawed a bit, but finally decided on a dining room table. Originally she had wanted something in a Greene & Greene style, but she just purchased a home and the style will not fit. So, she has sent me a picture of what she wants. Not my taste, but hey, it's not for me. I'm not sure what wood might work best. The top and legs are very thick, so it needs to be something that's pretty stable. I was thinking a soft maple. Birch? (The original is birch) Anyone have any suggestions? Also, anyone have any idea where I might find the hardware? Click image for larger version.
Name:	Zoe's Table 2.jpg
    • Overall Unextended: 86" long x 42" wide x 30" high
    • Overall Extended (1 leaf): 104" long x 42" wide x 30" high
    • Overall Extended (2 leaves): 122" long x 42" wide x 30" high
    • Leaf (2): 18" long x 42" wide
    • Tabletop: 3" thick
    • Overhang (at side): 2.5" wide
    • Overhang (at head): 6.5" for unextended table; 24.5" for extended table
    • Legs: 4.5" square, 27.5" high
    • Distance Between Legs: 64.5" at sides; 28" at head
    • Clearance Under Tabletop: 27.5"
    • Weight: 253 pounds
    www.wrworkshop.com
    Catalunya
    4,632
    Hi Rennie, I believe that the hardware is rather easy to find/make. The threaded tensor you can find it in any hardware store or ironmonger, remove the hook and the loop and use the central part. Then make the long parts out of an iron bar, with a 1/2" long thread at each end. Then fix one of those threaded loops (see image) on each side of it.
    I personally do not like the way this guy has attached the tensor bar to the leg stretcher, it makes it look too farfetched to me even if the original was like that.
    I would use an open loop hook screwed onto the stretcher and after puting the loop in close it.
    You can use a chain instead of a bar, or make an striking contrast using a polished stainless steel rod, try to find suitable parts at carwrecks or shipyards that do not necessarily need to be or resemble like the original ones, feel free to change those things to your liking, be flexible enough to accept that.
    As per the wood choice, why not use salvaged rail sleepers? they are hard, and treated with creosota, so wear a mask when working them if you use those.
    Best regards,
    Toni
    30,019
    Rennie, have you considered pine? I think birch would be my first choice, though.
    ...As per the wood choice, why not use salvaged rail sleepers? they are hard, and treated with creosota, so wear a mask when working them if you use those.
    I suspect the creosote would make working with the wood very difficult. In my limited experience working with rail ties, I saw they dulled a chainsaw pretty quickly and thoroughly. Also, would it inhibit proper adhesion of the finish?
    Constantine, MI
    7,891
    Ties, around hear at least, are pretty rough and usually softwood. I recently went shopping for some to use outside around a flower bed and could not find any suitable even for that. The creosote scares me both for finishing properties and for food contact.
    Another suggestion that came to me via PM was to seek out hardware meant for farm use, such as silos. However, I like some of your ideas as well. Had not thought of chain, but that would not offer any compression resistance and would have to be tensioned against the leg connection. This might loosen up over time.
    As for the ties, for a more rustic table perhaps, but this will be indoors and used as a dining table.
    www.wrworkshop.com
    5,322
    Tractor Supply probably has the type of hardware you're looking for, but it'll likely be galnanized finish.
    Probably not in Boise, but a ship chandlery would also have the deadeyes and turnbuckles. They'd likely beither chromed brass or stainless steel, though, and would be very pricey.
    As for the wood - what are they using for shipping pallets there in the PNW? I'd try a pallet sawmill. It'll all be rough stock, but then, so is that table, so it ought to work well. BTW, back here, pallets are often white oak, but sometimes poplar, too. It's also not uncommon to see several different species in one pallet.
    Seems to me that birch would work just fine as the original is also made from birch. Why complicate it?
    12,260
    I am with Toni go with rail sleepers. I disagree with Vaughn they are not all bad to work. Have seen some incredible furniture made out of railway sleepers they nice hard wood when finished ist beautiful.
    This is not a cheap table when you see it in Pottery Barn, table alone is running for CDN$2229.00 .
    http://www.potterybarn.com/products/...-dining-tables
    Just to give you an idea check out this site from where i came from
    http://www.kingsofsleeperwood.co.za/
    30,019
    Rob, from the looks of that site, rail sleepers in SA are quite different from those in the US. For one, they are hardwood (teak and ironwood). Ours are usually softwood (pine and fir are common) and chemically treated with creosote. Have you worked with any of the creosote-treated ones from the US? It ain't fun.
    Austin, Texas
    1,448
    Unless your daughter married a weight lifter, you might want to take the design and see how you can fake it... for example a hollow box construction rather than a 3 inch thick top (which may be unstable for warp and cracks as well). I can't imagine a 3 inch thick table top weighing over 250 pounds - how many people will it take to add a leaf or vacuum under the table.
    Charlie Plesums, Austin Texas
    Constantine, MI
    7,891
    Quote Originally Posted by Charlie Plesums View Post
    The description says 253 lbs. Don't know if that includes the leaves. I had thought to use 3" thick at the sides and 3/4" in the field. Just a thought.
    www.wrworkshop.com
  1. Mission Lamp Wood Choice
    By David Agnew in forum Designs, Plans and Sketches
    Last Post: 12-30-2013, 06:21 PM
  2. Wood turning tool choice
    By Jim C Bradley in forum Turning Tool Questions and Show & Tell
    Last Post: 10-29-2011, 04:59 AM
  3. Choice of wood for kitchen cabinets
    Last Post: 08-11-2010, 07:58 PM
  4. Bench wood choice
    Last Post: 10-31-2009, 12:38 AM
  5. Wood choice question
    By Ed Nelson in forum General Woodworking Q&A
    Last Post: 04-03-2007, 01:49 PM
