Results 1 to 10 of 14
Thread: Can I use a "cardboard" barrel as a chip collector?
    May 2009
    Lafayette, Indiana
    2,379
    Well my plans to do more woodworking have not been going my way. My work schedule just has not left much time or energy for this but I really really want to so I make the time whenever I can. Anyway.....I bought the 2 HP HF dust collector but still have not run any piping to it yet. I cut and sanded a few things in the shop a few weeks ago and the dust is VERY bad in such a small shop so I really want to get it up and working. I also did a lot of reading about dust collection and several of you have offered good advise to me as well. One thing that I read about was adding a "chip" collector to the system. The main reason I want to do this is so I dont have to empty my DC bags. I would like for most of it to go to another container that will be easier to empty. I found this "cardboard" barrel at work and wondered about using it. The inside of the barrel is coated in a wax type coating. Has anyone used a barrel like this or should I just get a trash can and a lid from Rockler?
    17,470
    tom some have used that type of barrel for the chips.. and i think you can make a top with some pvc fittings to get the separator to work, and save you some cash as well loo for some plans on chip separator..what happens is the big stuff stops at the card board barrel and the dust continues on to the filter bags..
    Wisconsin Dells, WI
    485
    That's the kind of barrel that came with my Onieda system, with one exception. Mine has a hole and flange in the lid to accept the ducting.
    I don't see any problem using that as long as you can figure a way to get the ducting into the barrel.
    5,317
    That type of barrel will work very well. Use two PVC or ABS toilet flanges from the hardware store, and a couple of pipe elbows, and you're in business.
    That type of barrell is better than the cheap trash cans available today IMHO.
    Bob
    Making saw dust in SW Louisiana
    May 2009
    Lafayette, Indiana
    2,379
    Quote Originally Posted by Robert Delhommer View Post
    Wow. This is good to know. These barrels get thrown out all the time at work. I grabbed an extra lid the other day as well so I can screw one up.
    Does there need to be a baffle on the inside or is it just an inlet and outlet?
    5,317
    Quote Originally Posted by Tom Baugues View Post
    A thein-type baffle would probably be the most efficient, but just having elbows on both the inlet and the outlet - facing in opposite directions - will work quite well.
    Austin, Texas
    1,447
    The idea of the chip separator is to make the input spin around the barrel, and as it slows down, the heavier chips drop. The lighter dust is then pulled from the slower part of the stream. In a cyclone the diameter is made progressively smaller, to keep the speed up and carry the chips down, then the air is pulled out of the center where it has practically stopped rotating. With a simple chip separator, it may only get a 1/2 revolution before it is pulled out, but if I were building one, I would look at an inlet that aimed the chips around the outside, and outlet in the center, with a tube that stuck down into the bin a few inches.
    I only use my chip separator on the jointer/planer where I make a large volume of chips. Since the chip separator reduces the effectiveness of the suction, I do not use it on the sander, saw, or other devices that make find ugly dust.
    Be sure you do not have an air leak in the separator. Not only will it reduce suction from your machine, but it disturbs the airflow, and messes up the dropping process.
    Charlie Plesums, Austin Texas
    30,002
    +1 for the Thien baffle.
    http://www.cgallery.com/jpthien/cy.htm
    Feb 2012
    central florida
    208
    I have the hf 2hp collector (Love it so far after 2 years) and I was using the bag system that came with mine just like the dust collector I used before. That was a real pain. I have recently rigged something up so I can collect the chips in a regular garbage can with a normal lawn and leaf bag in it. the bag is only to tie up so dust doesn't blow around when I move it or when the trash guys come. I just pull out the full can and put in the spare I have. Its basically a ledge and a riser that the collector body sits on. I have foam rubber in between the collector and the ledge that keeps the air and dust inside the can where it belongs.
  1. "Crime Doesn't Pay" or "No Good Deed Goes Unpunished" ?
    Last Post: 11-21-2013, 05:57 PM
  2. "Tornadoes" from my dust collector!
    By Gary McFarlane in forum Shop Tours
    Last Post: 09-19-2009, 04:30 PM
  3. Replies: 3
    Last Post: 12-07-2008, 08:06 PM
  4. "Dust Collector Remote"???
    By Lary Grassmeier in forum General Woodworking Q&A
    Last Post: 07-23-2007, 08:42 PM
  5. Cyclone chip barrel to lid seal question.
    By Jim O'Dell in forum General Woodworking Q&A
    Last Post: 11-22-2006, 06:37 PM
