Results 1 to 10 of 14
Thread: learned the hard way again today
    new york city burbs
    10,188
    my first mistake was sanding down the cherry doors to 220 grit.
    120 would have been more than sufficient.
    then my next mistake was being too lazy to go out and buy some prestain.
    then I used stain and got some blotchiness on some spots which makes me very unhappy.
    I rarely use stain.
    either I sand them all down again, but I doubt Ill ever get a good matching even color.
    not sure which direction Im going now, Ill wait for the stain to dry completely overnight.
    Not happy, who knows if minwax is a good stain choice, its just convenient
    Human Test Dummy
    Thomasville, GA
    5,992
    If you were farther south, a good suntan works well for cherry. I get blotches when I do my usual oil rub, but some hours in the Sun evens it out a lot.
    Bill Arnold
    17,471
    also you might be able wash the stain off with some mineral spirts if you do it soon allen
    Jun 2007
    4,944
    Many years ago I used a lot of Minwax stain. It did not give me any trouble. However, I was not using cherry, I was using red oak, birch, and pine mainly.
    I am sure that that piece of knowledge is worth every cent you spent for it.
    Enjoy,
    JimB
    VOTING MEMBER
    new york city burbs
    10,188
    too late for that, I tried sanding some of the back of a door this morning and reapply stain, but I think at this point I have to leave well enough alone, and not make the mistake on the cabinet doors.
    Mr. B-oak, pine, ash, it takes any stain Ive applied great. I get blothes if Im not careful with maple or cherry.
    Im leaving it hang for a while, I have to go start and make a medicine cabinet and pullout hamper.
    Human Test Dummy
    12,251
    Well Allen i had some good success with mix waxes alternatives sold at our depot. The varathane range of gel stains.
    I used them before i even knew squat of what i have learnt here and they were pretty idiot proof on plywood red oak for a finish that changed it to more like white oak.
    Also yesterday i stained some MDF with gel stain and a sponge brush and it came out real well to my surprise.
    BUt i can see why some guys develop a finishing routine with a certain known range of go to approaches and then stick to it.
    At some point in time try the deft lacquer range and try to spray the stuff. Larry taught me and man i was like a kid in a candy store when i saw the result. and to demonstrate we took pieces of scrap that had not even been sanded.
    I aint ever done anything YET with Cherry. First need to get hold of some and be brave enough to go for it.
    Mar 2011
    Painesville Ohio
    131
    I find danish oil works well with cherry.
    "Its only by minute attention to every detail that you will achieve perfection"
    new york city burbs
    10,188
    rob, Im all set to spray, but spraying in my garage is not an option.
    I filled in a 3foot by 3 foot piece of cement to repair a sidewalk block, and I had to go to court because I didnt obtain a permit to lay cement. IM sure the nn had alot to do with it.
    If I spray, Id probably have a warrant issued for my arrest by the end of the day.
    Not worth it. I would have loved to move my shop, this being one of the reasons.
    Aint happenning right away, so hand finishes it is, and I do it in my home.
    larry had mentioned gel stains when I did my first project, the radiator covers, I should have opted for that again. Not sure if it prevents blotches, but gives a more uniform coat.
    After I put some finish on it, Ill post a picture.
    Human Test Dummy
    new york city burbs
    10,188
    Quote Originally Posted by John French View Post
    I also like any of the oils on cherry.(i use waterlox alot) My son wanted more reddish.
    Human Test Dummy
    new york city burbs
    10,188
    Im not making these doors over, the worst blotches are in the panel raised board.
    I miss my old finish room, it was twice the size.
    Attached Thumbnails Attached Thumbnails cabinet 238 (Medium).jpg   cabinet 237 (Medium).jpg   cabinet 236 (Medium).jpg
    Human Test Dummy
  1. I learned something new today.
    By Karl Brogger in forum General Woodworking Q&A
    Last Post: 02-25-2015, 06:31 PM
  2. I learned something today
    By Julio Navarro in forum General Woodworking Q&A
    Last Post: 01-21-2012, 01:58 PM
  3. What I learned today!
    By Paul Gallian in forum Off Topic Discussion
    Last Post: 06-22-2009, 09:43 PM
  4. learned something today
    By Mark Kosmowski in forum General Woodturning Q&A
    Last Post: 04-04-2009, 10:55 PM
  5. What I learned in the shop today . . .
    By Jim Mattheiss in forum Off Topic Discussion
    Last Post: 01-16-2008, 03:01 AM
