Results 1 to 10 of 15
Thread: Frame and Panel router bit set question
    12,251
    Ok Bryan and Allen have tipped my scale and its time i venture forth into the frame and panel world.
    Can you guys offer suggestions as to a decent set. I dont intend buying twice and i aint going into the furniture business but i do wish to have a good set that will last. Only 1/2 " shanks.
    There are so many i have seen out there i cannot tell what to look for and who is got the "it"
    Any recommendations preferably would like to know you either own it or have used it and would choose it therefore if you had need.
    Thanks in advance
    Also what do you use for spacing when it comes to putting your panel into the frame. I have seen rubber balls and what looks like rubber rod tappered at each end.
    I presume the go to approach is also to finish the panel before one inserts it to cater for woodmovement is this neccessary?
    Rob,
    I just bought my first set. I was very much impressed with the MLCS Katana set. They aren't cheap but they cut red oak like a hot knife cutting warm butter.
    Here's a link: http://www.mlcswoodworking.com/
    No relations with MLCS other than being a happy 1st time customer.
    Ken
    I have a Wood river set that Woodcraft sells and a set from MLCS. I like both sets and they have seen alot of use. I did my kitchen, my daughters bedroom set, a couple of cherry built-ins and some other odds and ends with the MLCS set and have yet to sharpen it.
    The cope and stick bits from the Woodriver set are very similar to a set of shaper cutters in that you can set the infeed fence deeper than the outfeed fence and cut any defects off the edge.
    Thomasville, GA
    5,992
    Here's another vote for MLCS. I have a couple different styles of their regular sets (not Katana). I've done a fair amount of red oak and have only lightly honed one set one time.
    I've used space balls but find I need to cut them in half to work like I want.
    Also, when setting up a set the first time, I make a pair of setup blocks (cope and stick) as soon as I have a correct match. Makes it much easier to set up in future sessions.
    Bill Arnold
    new york city burbs
    10,188
    I will only buy red or orange bit sets from now on. I find their quality unmatched.(at least for me)
    buy a few packs of spaceballs, they make it simple.
    when you buy a cope and stick set, as mine did, it will tell you how to determine panel size, as well as stiles and rail size, according to the set you purchase. (mine has a 7/16 tenon)
    I dont size the panel after I make the stiles and rails, I figure out all the measurements first, and I havent had a problem with the 6 or 7 doors Ive made so far, so I guess following the manufacturers directions, makes it easy, even for me.
    (I laminated the instruction sheet, because I reread it everytime I start to use the bit set)
    Human Test Dummy
    Dec 2008
    Santa Claus, In
    4,779
    No problems here from Eagle America or Freud.
    Independence, Kentucky
    1,354
    I am happy with the MCLS set, I also have a set from Holbren that is good Neither on breaks the bank I have used the MCLS set for over five years with no dulling so far.
    10,604
    I have a MCLS set also. No problems at all.
    Rochester, NY
    23
    I have been pleased with the Whiteside sets that I purchased from WoodWorkersWorld.net. The cope and stick matches are very good and the have a fairly decent selection of profiles available.
    A quick alternative to spaceballs would be to lay down a 1/8-3/16 bead of pure silicone caulk on a piece of wax paper. After ihe caulk dries, cut it into pieces and insert a couple in each groove before inserting the panel. I do prefinish the panel inserts before assembly.
    Chip Hamblin
    Rochester, NY / Dwight, ON
    FWW Registered Voter
    5,321
    Quote Originally Posted by Steve Southwood View Post
    Steve,
    Did you know that MLCS bought Eagle America a couple months ago? The EA headquarters/store in Chardon, Ohio is closed now, and their newest catalog is now full of MLCS products.
  1. Frame and Panel Cabinet Doors Question
    Last Post: 06-27-2010, 05:25 PM
  2. Frame and panel fixing question
    Last Post: 06-24-2009, 07:32 PM
  3. A Frame and Panel Cabinet
    Last Post: 11-23-2008, 11:07 PM
  4. Frame and panel chest of drawers question.
    Last Post: 11-23-2007, 06:44 AM
  5. Frame and panel methods
    Last Post: 11-17-2006, 04:52 PM
