Results 1 to 10 of 21
Thread: My cyclone dust control system clogged up. Why?
    Toronto, Ontario, CANADA
    2,332
    Earlier this week, I was preparing a lot of rough lumber with a jointer and planer. Usually after a couple of hours of this, I need to empty the 35 gallon barrel beneath the cyclone (an Oneida 2hp Commercial). So I checked and, to my surprise, the barrel had not reached the full mark. It turns out that I should have checked more completely because, if I had, I would have observed that the barrel was almost empty.
    After about another hour, the pick up on the jointer stopped working:
Name:	Dust control jamb 01 -no pickup on jointer -small.JPG
    My first thought was that there was a jamb somewhere in the jointer or the drop to same. There wasn’t and I was confused.
    I finally got around to really checking the barrel and found this:
Name:	Dust control jamb 02 -almost empty barrel -small.JPG
    Now, I was really confused.
    Next, I took the elbow off the end of the main pipe coming out of the dust control unit. There were chips sitting within the pipe:
Name:	Dust control jamb 03 -chips remaining in pipe -small.JPG
    OK this stuff must be gathering somewhere and I am running out of places to check. How do things look in the funnel about the barrel? Here is photo looking up into the mouth of the funnel:
Name:	Dust control jamb 04 -chips inside funnel above the barrel -small.JPG
    The funnel was completely filled and the material was really jammed in. I thought that probably a piece of larger material had been sucked up and wedged in somewhere thus causing the problem. But, there was no such thing. I stuck a broom handle up into the funnel loosening the material and getting it to fall down and I found no large pieces of anything. I still have no idea what caused the material to gather in the funnel rather than dropping into the barrel.
    Also, there was about a barrel full of material in the funnel, but I was pretty sure that I had generated more chips and dust than that. Where was the rest?
    I took the tray off the bottom of the filter and found this:
Name:	Dust control jamb 05 -chips in bottom of filter tray -small.JPG
    And, in the filter, I found this:
Name:	Dust control jamb 06 -chips clogged in filter -small.JPG
ID:	5817 Click image for larger version.
Name:	Dust control jamb 07-another photo of the clogged filter -small.JPG
    The filter was completely filled and, if anything, it was jammed tighter than it was in the funnel.
    Here is (a small) part of the mess on the floor that I created in emptying the filter and the funnel:
Name:	Dust control jamb 08 -the mess on the floor as I unclogged things -small.JPG
    Once the chips were out of the filter, cleaning out the rest was quite a chore. I don’t have a compressed air machine and I expect that would have made the job easier. What I ended up doing was banging the end on the floor about 10 times, vacuum up the residue, bang it another 10 times, vacuum up the residue, etc. etc. etc. Stuff kept falling out. The following picture shows the result of 10 thumps after having already thumped the filter about 500 times:
Name:	Dust control jamb 09 -filter still depositing dust on floor after more than 500 bangs -small.JPG
    After about 1,000 thumps stuff stopped falling out and I cleaned out the interior with a vacuum. I guess that I am going to have to break down one of these days and purchase a compressor.
    To wrap this up, here is a photo of the totally disrupted shop part way through the investigation and clean up:
Name:	Dust control jamb 10 -view of the centre of the shop during clean up -small.JPG
    By the time I completely cleaned up everything, I had gathered 2 and half barrels of chips and sawdust.
    I am happy to report that, once I put everything back in place, things worked well and, in about an hour of woodworking, I have already filled the barrel to the point.
    I am very interested in hearing theories about how the system got clogged up in the first place. It remains a total mystery to me.
    The trouble shooting part of my manual is no help. I plan write to Oneida soon and ask if they have any ideas about what may have happened.
    Cheers, Frank
    Steve Clardy Guest
    Air leak in the barrel?
    2,332
    Quote Originally Posted by Steve Clardy View Post
    I did check this and both the barrrel and the clamp that holds it in place seem to be leak free.
    Cheers, Frank
    810
    Any chance that the temp and humidity in the air in your shop was at or near dewpoint levels and the sawdust just glued itself to the inside of the filter system after it passed thru' the venturi that the cyclone creates? That compression/decompression of the air thru' the cylone could possibly cause a serious lowering of temperature and cause the moisture in the sawdust to condense and stick to the insides of the unit?
    2,332
    I also posted a similar thread on the Canadian Woodworking forum and just received a very plausible suggestion there from someone who goes by the handle "Maintenance". That person said:
    Well Frank, from what I have, recently read ( I have no experience with this), when the barrel becomes too full, the blower begins to draw chips out of the barrel. Then the filter becomes totally clogged, then the airflow is insufficient to work at all, and the dust just packs in. It sounds like what I read is true. Hope that explains it.
    I think that this could very well be it.
    I have now written both to Oneida and to Welbeck Sawmill (where I bought the system) describing the situation. Let's hope that they clear up the msytery soon. By the way, I could find nothing like thsi described on the Oneida web site.
    Cheers, Frank
    Northwest Indiana
    104
    Steve's on to something. Most likely an air leak in the barrel,lid and or the hose leading down will cause an updraft in the cyclone. After that the chips have nowhere to go but out the impeller and in to the filter. Or a clogged filter will cause this also. I feel for you It's a mess, especially the filter. The Oneida unit I had before did the same thing. Another reason I like my clearvue. (you can see the the chips moving down into the bin)
    There is unrest in the forest,There is trouble with the trees
    For the maples want more sunlight,And the oaks ignore their plea's. N.Peart
    Odessa, Tx
    1,813
    That would certainly be my First guess.
    And for FRANK, I don't know about that "high dollar" Vac you have, , but on most shop type vacs, you can take the vacuum hose and plug it into the outlet side, and that would give you plenty air to blow out your filter pretty good, especially if you lightly tap on the filter as you blow on it. That is how I always clean my vacuum's filter.
    2,332
    Quote Originally Posted by John Bartley View Post
    Good theory, but I doubt it very much in my case. The shop is relatively dry and I never let the temperature get below 10 degrees (I think that's about 50 farenheit).
    Cheers, Frank
    2,332
    Quote Originally Posted by Norman Hitt View Post
    ..And for FRANK, I don't know about that "high dollar" Vac you have, , but on most shop type vacs, you can take the vacuum hose and plug it into the outlet side, and that would give you plenty air to blow out your filter pretty good, especially if you lightly tap on the filter as you blow on it. That is how I always clean my vacuum's filter.
    I did think of that but my "high dollar" Vac (as you put it) does not seem to have any such output connection.
    posted later: OK, I checked again and I found the ooutflow opening hidden away down near the floor. The "air blast" produced is not bad and I will test it tomorrow and see how it does blowing upon the pleats in the filter.
    Cheers, Frank
    2,332
    I doubt there is a leak anywhere
    For all you folks suggesting an air leak, I am almost certain that this is not the case. This evidenced by the fact that, when the barrel is near empty, there is so much suction in the system that the barrel gets pulled of the ground. Also, after cleanup, everything works OK again and I suspect that it would not if there were a leak somewhere.
    Cheers, Frank
  1. Handheld Router Dust Control
    By Dan Gonzales in forum New Tools
    Last Post: 06-25-2014, 01:24 PM
  2. Miter Saw/ RAS dust collection, vac or cyclone
    By Dave Black in forum Jigs and Fixtures
    Last Post: 08-09-2011, 10:20 AM
  3. Cyclone dust bin sensor
    Last Post: 03-08-2010, 03:32 AM
  4. Dust control in the workshop for beginners
    By Chas Jones in forum General Woodturning Q&A
    Last Post: 02-12-2009, 01:26 PM
  5. PC Enclosure for Dust Control?
    By Brent Dowell in forum General Woodworking Q&A
    Last Post: 11-29-2008, 01:18 PM
