Results 1 to 8 of 8
Thread: Wood Bleach
    Wood Bleach
    Has anyone used wood Bleach on wood and when is the right time to use it ..................MB
    Usually Busier than a Cat In A sand Box : Arkansas Red Wolf & Razorbacks Fan
    Yes Marshal I have. I got the 2 part mix from woodcraft and used it just prior to applying a clear water based poly. I used the water based since it was non yellowing. It was on the dove that Toni carved for me on the church commission and after going on two years it is still pure white.
    OK Larry but what was the reason that you used this for or the purpose of it before the finish was applyed ............MB
    11,828
    I have used Clorox on holly. Made slightly yellow into white.
    May 2011
    So. Florida
    268
    Quote Originally Posted by Marshall Border View Post
    I don't use it prior to finishing, unless a determination that it's necessary,i.e., to match up if need be. But I don't use it as a matter of course. The times to use it may be if the wood has darkened, or developed mold or mildew, or discolored from chemical sources, or UV differentials. In lieu of bleaching to clean, you could try TSP (tri-sodium phosphate), available at home centers in the housewares section. It's basically a strong cleaning agent. Clorox can work, or a better bleach would be oxalic acid. What ever you use make sure you neutralize the bleached area, and allow to completely dry before doing any further finishing.
    I knew a furntiure refinisher that used Clorox one time - but had forgot what the reason was he used it for . Thanks for sheding some light on this subject for me ...............MB
    Marshal here is a thread showing the piece I bleached. Painting would have covered up some of the details in the carving.
    30,008
    I've used Clorox on turned pieces to lighten the color of the wood. (Sort of like Frank, I used it to turn blond ash into semi-white ash.) Be aware, though, that if left on the wood long enough, Clorox will start to eat away the wood. Here's a close-up look at an ash bowl that was sanded smooth down to 600 grit, then soaked in Clorox for a day or two. (I was wanting the eroded look.)
Name:	Bowl 090 Detail.jpg
    And I did all my bleaching before applying the finish.
  1. Recycled Wood and Wood Storage
    By Paul Douglass in forum Jigs and Fixtures
    Last Post: 10-24-2013, 01:47 AM
  2. Replies: 12
    Last Post: 02-08-2011, 11:36 PM
  3. New wood stash and drying wood
    By Dave Black in forum General Woodworking Q&A
    Last Post: 10-25-2010, 09:53 PM
  4. Wood glorious wood .....( from the movie of Oliver Twist)
    Last Post: 11-09-2009, 10:30 PM
  5. wood screen door build - which wood should i use?
    By Mike Gager in forum Carpentry and Construction
    Last Post: 03-07-2009, 02:24 AM
