Results 1 to 10 of 11
Thread: New Bed
    5,533
    New Bed
    This weekend's project has been building the LOML a new bed frame.
    -Ned
    5,533
    -Ned
    5,533
    Welll... at least I don't need a board stretcher...
    SO... the last bed I made, I managed to make it just a wee bit tight to the box spring...
    The LOML pointed this out to me the other day... and said 'Don't forget to add some room this time...'
    SO I did, in Both dimensions...
    Doesn't Look bad...
    only when we put the box spring in... it has barely 1/2" on either edge supported by the 2x4's. and almost 3" of room to spare... on both edges...
    SO, since it is well past dark, I'm really tired from pushing hard to get this done today, we're going to sleep in the guest room tonight. Tomorrow we'll dis-assemble the frame, and the two end rails are going to get cut down so there is just about an inch on either side... going to screw in a spacer on the headboard end (Lori says she'll get claustrophobic with that tall vertical piece) and the headboard will be re-designed just a tad... ) Can you say 'design opportunity"? I thought you could.
    -Ned
    I keep my board shrinker in the same cabinet as the board stretcher and sky hook. Never know when I might need to use one of them.
    5,533
    2x8's for the legs, 2x6's for rails and further support (under the 2x4 support rails, as well as under the side rails).
    As usual, still needs a coat of finish (I'm going to stick to my guns, and next weekend it will get at least 2 coats of poly on it.
    -Ned
    Southeast Pa
    2,019
    Good work Ned..
    Garry
    Constantine, MI
    7,891
    Looks strong! Nicely done.
    www.wrworkshop.com
    Sep 2010
    Southern, Illinois
    106
    Nice job on the joints Ned.
    LOL - At the books under the bed! I've got about eight books all at various stages of being read under my side. Wife has the nightstand more than an arms reach away from the bed....like I'm going to get out of bed to put my book down.
    Oct 2007
    Schenectady, NY
    912
    Nice work. Very Greene & Greene stylish.
    Don Orr
    Woodturners make the World go ROUND
    Sep 2007
    Plainwell, Michigan
    4,857
    That will do the job Ned, and the missis is happy, don't get much better then that
