Results 1 to 8 of 8
Thread: fill holes in foundation
    Rhode Island
    800
    Question fill holes in foundation
    Guys, we had the old oil tank in our basement taken out & according to them the fill pipes must be taken out also. So they took them out & put a tad bit of expanding foam inside. I want to fill them with either concrete or something similar.
    What is the best thing to use & how do I do it? I really don't want to get a 50lb bag of cement to fill 2 small 3" holes.
    Thanks
    10,600
    I'd use hydraulic cement. It will be waterproof.
    You can get it in small buckets.
    Thomasville, GA
    5,988
    We've used concrete patch that comes in 1qt or maybe a 1liter bottle from the borg. It's made for small concrete patches.
    Bill Arnold
    30,002
    The concrete patch stuff from the Borg should work fine, Chuck. Out of curiosity, is there a problem with the expanding foam? I'd think it's as good of or better seal than a concrete patch.
    Floydada, Tx
    1,941
    hydraulic cement works great for small patches like that.
    5,317
    Another vote for the hydraulic cement. Expands a bit as it dries, and makes a waterproof seal that'll last somewhere near forever. Gotta work fairly quickly with it, though - it begins to harden after only a few minutes.
    13,353
    I used some of that hydraulic cement to patch some cracks in a pre-cast concrete irrigation tank last year. Worked great!
    It comes in little buckets, so no worries about a 50# bag.
    (To be honest, the 'pre-cast irrigation tank' is something that most folks have buried underground and use for fluids other than water. Just another one of the 'creative' solutions the previous owners installed here)
    Rhode Island
    800
    Vaughn,
    They only put in about 2" of foam just to keep out small insects & the foundation is about 8" thick.
    Thanks, I'll go get some of the hydraulic cement.
  1. Watering the foundation
    Last Post: 07-21-2013, 04:11 PM
  2. Trying to fill my pen inventory
    Last Post: 03-12-2011, 01:56 AM
  3. A few small gaps to fill
    Last Post: 11-18-2008, 01:57 PM
  4. Shed Foundation
    By Mike Gabbay in forum Carpentry and Construction
    Last Post: 12-10-2007, 09:59 PM
