Results 1 to 6 of 6
Thread: The best/safe finish for a crib
    Mar 2011
    Painesville Ohio
    131
    Going to be making my grandaughter a crib. What is the safe finish to use for kids. I know there are new rules about this. The wood will be Maple and Cherry. Any help would be great. Have a HVLP spray system. Thanks..
    "Its only by minute attention to every detail that you will achieve perfection"
    Austin, Texas
    1,448
    Rule 1 - Shellac is edible. Melts in your mouth, not in your hand, is chocolate coated with shellac.
    Rule 2 - almost any modern finish is fine, once it has cured. I would probably use a water base lacquer, since it sprays well, has burn in so I can go back and get the odd positions I missed (with all the spindles, etc.), and is marvelously repairable. But as active folks here know, I have a strong bias for Target Lacquer.
    Charlie Plesums, Austin Texas
    30,017
    Charlie pretty much said exactly what I was going to suggest. Shellac is a traditional "kid stuff" finish, but all modern finishes are safe once cured, and waterbased lacquer would be my choice for its durability and repairability.
    Mar 2011
    Painesville Ohio
    131
    Thanks guys. The best place to get the "target lacquer" at ?
    30,017
    Quote Originally Posted by John French View Post
    Target Coatings:
    http://www.targetcoatings.com/
    I think Charlie is mostly using their EM6000 product. I've used the predecessor to EM6000, which was called Ultima Spray Lacquer (USL).
    Mar 2011
    Painesville Ohio
    131
    Thanks again. Order sent.
  1. crib finish
    By Kevin Sarkody in forum Finishing School
    Last Post: 07-20-2009, 03:17 AM
  2. Crib Finish
    By Bill Casassa in forum Finishing School
    Last Post: 03-31-2009, 08:55 PM
  3. Poplar Crib Finish
    By Chris Marlor in forum Finishing School
    Last Post: 03-05-2009, 02:01 PM
  4. Kid safe finish?
    By Matt Dunlap in forum Finishing School
    Last Post: 03-23-2008, 07:11 PM
  5. What finished is crib safe?
    By Doug Sinjem in forum Finishing School
    Last Post: 09-19-2007, 01:53 PM
