Results 1 to 4 of 4
Thread: long lasring exterior paint
    Mar 2012
    Paynton Saskatchewan Canada
    27
    I need to buy a long lasting exterior paint. something that doesn't have to repainted every year or two. Any suggestions? Brands?
    I have used Behr products for many years. For exterior paint that does not break the bank, this would be my choice
    Anybody can become a woodworker, but only a Craftsmen can hide his mistakes!
    The Bible tells us to love our neighbors, and also to love our enemies; probably because they are generally the same people.
    5,323
    You don't say where you're located, Michael - and that would help a lot.
    Weather is the main factor in determining paint longevity.
    Heavy sunlight, usually on the South and West sides, can cause rapid paint failure. When I lived in SoCal, I need repainting on the South side of my eaves and fascia almost yearly, regardless of prep. When I lived in a wooded area in South Carolina, it was the moss, mold, and mildew on the East and North sides that needed frequent attention. When I lived near Seattle, in the Pacific Northwest, it was again mostly the North side, but the near-constant moisture caused problems all around.
    You'll noticed I mentioned "prep." That's another major factor. The surface under the paint needs to be clean and dry before the paint is applied, and any bare spots need primer. Don't just put paint over bare wood. I used to preferoil-based primer because I always felt I got better penetration, sealing, and coverage than with the water-based stuff. I understand the newer water-based primers are better, but I haven't tried them. I do like the water based top coats, though, and they adhere well to thouroghly dried oil primer (I let the primer dry for a couple days.) Brands I've used in the past were Behr, Olympic 'Overcoat,' and Lucite. All worked very well for me. Benjamin Moore paint is very good, too, but pricier than the others. I tried Sears 'Weatherbeater,' but didn't like it. It didn't hold up well to mildew in the PNW, or dry hot sun in SoCal for me. YMMV...
    Mar 2012
    27
    I'm in saskatchewan canada. So hot hot summers and deep freeze winters.
  1. Wood for exterior door
    By Brian Corrigan in forum Carpentry and Construction
    Last Post: 08-09-2013, 01:18 PM
  2. Exterior glue question
    By Bob Gibson in forum General Woodworking Q&A
    Last Post: 05-24-2013, 03:30 PM
  3. Wood Type for Exterior
    By Sayer Fancher in forum General Woodworking Q&A
    Last Post: 11-21-2012, 12:28 PM
  4. How much clearance around an exterior door?
    Last Post: 08-21-2012, 08:21 PM
  5. Refinishing Exterior Oak Door
    By Lawrence Miller in forum Finishing School
    Last Post: 09-16-2010, 07:24 PM
