Results 1 to 4 of 4
Thread: Best way to joint boards without table saw or jointer?
    I was wondering what is everyone's opinion of the best way to joint boards without a table saw or jointer?
    Jan 2011
    3,798
    Well, if I didn't have access to either, I'd go with squaring up the face via hand plane...squaring an edge, probably use router table & a straight bit or, flush cutting bit & a straight edge guide 'if' the the piece were say 3/4" or so. thicker would lead me back to the hand plane.
    One time, years ago on a job-site, in a pinch, we over-lapped 2 pieces, used another for a guide and ripped thru both at once with a circular saw. It accomplished what we needed, but wasn't what one could call fine furniture quality.
    Sure those more experienced than I can offer more in-depth replies.
    Floydada, Tx
    1,941
    Straight edge and a router w/ spiral bit. If the board is warped to much I will snap a chalk line and trim with a saw first.
    My first choice is neither jointer nor table saw. I go straight to a # 7 or #8 jointer plane. Even if I would use a table saw or jointer, I'd clean up those cuts with a jointer plane.
  1. How much Hard maple can a Jointer Joint?
    By Brent Dowell in forum General Woodworking Q&A
    Last Post: 05-24-2015, 12:52 AM
  2. Delta jointer 37-220 table removal
    By Jack Jard in forum General Woodworking Q&A
    Last Post: 09-10-2010, 08:01 PM
  3. Help selecting Bandsaw, Jointer, Planer, and Table Saw
    By Douglas Cox in forum New Tools
    Last Post: 02-27-2010, 01:50 AM
  4. M and T joint ?
    By jim capozzi in forum General Woodworking Q&A
    Last Post: 02-01-2009, 04:51 AM
  5. Box (finger) joint jig for router table
    Last Post: 01-09-2008, 06:18 PM
