Dennis, it's funny you mention this. I was setting the iron on a jointer plane (8) the other day and I made a few paper shavings cause I could then chuckled a bit to myself and set it a lot deeper to match the task at hand.
It's fine to be a fired up about the process, it's especially easy with hand tools... but, in my opinion, to be a purist with hand tools you have to keep in mind that practical and cool are not the same. There is no reason for a 15 lb jointer plane to make paper shavings for a half hr to joint one board when it can be done is 10 minutes when set more aggressively. Sure, a smoother should take fine shavings because that's it's job...
So that said, I guess you could say I'm a process guy. I think a lot of furniture building cave men will tend to be process guys because we are so few and so protective of our passion. I feel if you are proficient with hand tools then power can be as much a burden as a help. I also feel those bound exclusively to power tools lack the ability to go beyond the realm of square boxes quite as readily... Almost as if power tools are a crux, square cutting machines that don't as readily lend themselves towards the creative process.
I've been known to go through a process purely for the process but I really wouldn't need a process without an end product in mind. Despite this, brand me a hand tool'n, dark ages, cave paint'n Neanderthal process guy I guess
tom~
