Results 1 to 10 of 27
Thread: Porter cable orbital sander caught fire
    Mar 2012
    Malcolm, NE
    35
    So I bought a new porter cable orbital sander today and was sanding my tabletop between coats of polyurethane. I sanded the whole tabletop and the extensions, then shut it off and set it in my shop stool. I grabbed some sandpaper and started sanding the edges of the table by hand. After a few minutes I thought I could smell something burning. After another minute or so, the smell was getting stronger. I looked at my new sander and noticed it was smoking. I picked it up and the dust extraction bag was starting to smoke pretty good. I took the bag off and tried to dump out the contents but nothing was coming out. I walked to the front of the house to run some water on it from the spigot. By the time I got there the bag was just starting to flame up. I got it put out.
    Anyone ever have that happen? I'm just glad it wasn't later and I didn't sand then shut it off and go inside to bed. Probably would have burnt the house down!
    Wow! I think you were very fortunate to have it happen when you were there to see it. Could have been a disaster. I wonder what sparked it. Do you think it was electrical, or a spark from sanding (which doesn't seem likely if you were sanding between coats)?
    Mar 2012
    Malcolm, NE
    35
    I don't know what caused it. Every part of the sander was cool when I picked it up, except the dust extraction bag.
    13,462
    Wow, Sounds a little scary. Hopefully they make it right, but might consider another brand.
    Central NY State
    3,374
    I had something similar happen once, but it was totally my own fault. I was using a belt sander to flatten the back of a very abused chisel. sparks flew up the vacuum's hose, into the dust bag, and it began smoldering.
    Your experience however, seems quite a bit worse. Any chance the sandpaper hit a bit of metal, sending sparks? Hard to believe the motor brushes spark enough to ignite the dust, but maybe. In any case, this is really dangerous. Have you thought of contacting the consumer products safety agency? Please let us know the outcome.
    Mar 2012
    Malcolm, NE
    35
    I'm pretty sure I didn't hit any metal with it. I was just gonna return it to Menards and get a different one. I thought about contacting the company, but I don't really want to have to send it in to them and wait for them to do whatever they will do and be without it for who knows how long.
    NH
    4,012
    Maybe we ought to find out why it flared up before we go after the manufacture.
    Stupid hurts.
    NH
    4,012
    Just for fun run it with out the dust bag on in the dark to see if the sander is shooting sparks into the bag. If it is than get the company on the horn and let them know. So they can look into the problem and do a recall if necessary.
    Stupid hurts.
    17,475
    i got agree with chuck on doing that dry run test and then contact manufacture if you just got menards theproblem wont be addressed properly you get new sander but possible others wont know its a problem and the manufacture wont get to fix a problem they may unaware of.
    Mar 2012
    Malcolm, NE
    35
    As soon as I get back home in a couple hours I'll do the dry run and let you guys know how it goes.
  1. Best Orbital Sander under $100
    By Jeff Bower in forum New Tools
    Last Post: 12-02-2015, 02:23 PM
  2. Replies: 0
    Last Post: 03-06-2012, 01:35 PM
  3. Porter-Cable 352VS 3"x21" Belt Sander
    By Rob Bodenschatz in forum Old Ads
    Last Post: 02-21-2010, 07:32 PM
  4. Belt Sander or Orbital Sander
    By Dawson Mossman in forum New Tools
    Last Post: 09-18-2009, 01:03 AM
  5. Porter Cable 390 Sander
    By Mike Henderson in forum New Tools
    Last Post: 06-27-2008, 04:15 PM
