Results 1 to 9 of 9
Thread: Hackberry
    Oct 2007
    Indianola, Ia about 12 miles south of Des Moines
    440
    Hackberry
    Has anybody out there used hackberry for flat work. I have seen a few turnings, but no flat work that I can think of. I have access to a 26-28" hackberry tree that I can get 3 8-9' logs out of. How does it work conpared to red oak?
    Oct 2009
    Lindale, TX
    84
    I've never worked it, but I've been told it works like pecan which can be difficult as it has interlocking grain and likes to tear out with hand tools. I've seen pictures of cabinetry built from Hackberry and it was very pretty. Just from what I've seen of it finished, it would be worth it to me to grab those logs, but I've also got a good friend with his own mill and solar kiln.
    13,442
    I had many times I wanted to use hackberry, as it's root were clogging up the sewer line and causing my basement in my old house to flood. Sadly to say, I never got around to trimming it off at the ground as my wife would not let me.
    11,831
    Forget it. I think there is a law or something that says it MUST be used only for turnings.
    That is why it finishes so beautifully with things round.
    17,472
    rex dont listen to FRANK his head is still dizzy from his turnings.. its not like oak, it looks like a ash with some greenish to gray heart wood its realitly soft but not as soft as butternut i got some drawers made from it and made a box once with some in it.. get it cut into lumber its worht the time to do so it spalts great too.. alittle fuzzy when sanding but pretty stable and strong.
    Oct 2007
    440
    Frank would it still be against the law if a few pieces found there way to your spinny thing? I have some laying here in the shed, but it is dry.
    Westphalia, Michigan
    955
    One issue with Hackberry is that the heartwood is relatively small in diameter to the sapwood. It takes a big tree to get the nice colored heartwood. At least this is true with the trees I have seen in Michigan. The exception is when you allow it to spalt then you can get nice black lines in the white wood.
    I'm a certifiable tree hugger. (it's a poor mans way of determining DBH before cutting the tree down)
    4,552
    Rex I made several hundred 2X4 benches out of it and loved work with it. Most of them went to Cal and they though they were getting a strange new wood
    Well worth milling up and it can be stained and painted and I clear finished a LOT of it.
    A Turn N Time
    Frog Pond Guitars
    Oct 2007
    440
    I will go ahead and drop it this winter if the snow doesn't get too deep. Also need to drop a dew others and get them cut up also. We will see what happens.
  1. More spalted Hackberry
    By Chuck Ellis in forum Lathe Project Showcase
    Last Post: 11-15-2013, 02:46 PM
  2. My Hackberry
    Last Post: 01-20-2013, 04:48 PM
  3. Spalted Hackberry
    Last Post: 01-19-2013, 11:02 PM
  4. Spalted Hackberry
    Last Post: 12-18-2012, 02:21 PM
  5. Hackberry bowl
    By Paul Gallian in forum Turning Tool Questions and Show & Tell
    Last Post: 04-04-2010, 09:33 AM
