Results 1 to 9 of 9
Thread: Bosch Multi-X MX25EC-21 oscillating multi-tool
    Independence, Kentucky
    1,355
    I had a need for a oscillating Multi Tool so I pulled the trigger a Bosch refurbished unit. I have to say that I am really impressed with this tool, and I am sure I will find a lot of uses for it now that it is in the shop, It is smooth and fast cutting with variable speeds and soft start. Just wondering if others have this or other makes, and how you like them? I must admit that I was skeptical before I bought it about how much I would use one, but now that I have used it a little, I think it will be a go to tool for a lot of things.
    wait a minute I'll go and clean my glasses, I am haveing a hard time seeing it.
    Quote Originally Posted by Charles Hans View Post
    I got the Bosch several months ago and am very pleased with it. I had the Rockwell corded prior and was glad to see it go.
    Jack
    Villa Park, CA
    1,407
    I use the Harbor Freight corded oscillating tool. It's not a tool that gets a lot of use so I bought the cheapest version of it. Works well when I need it.
    I've also used the corded Dremel version of the tool and there wasn't much difference between the Dremel and the HF in terms of getting the job done. The one thing I noticed was that the Dremel got really hot on extended use - so hot I couldn't hold it normally.
    Mike
    Ancora imparo
    1,355
    Don are you saying I need a picture?
    I have heard that the harbor freight version is a very good value, but I am Bosh guy since I have had such good luck with them, and the refurb price was a good deal I thiught
    10,604
    I have the HF model as well. I think that I have used it 3 times in the past year. For $20.00 it serves the purpose well. However if I was going to use one on an ongoing basis I would buy a Bosch (I also really like Bosch tools) or other quality brand.
    new york city burbs
    10,188
    Quote Originally Posted by Mike Henderson View Post
    Mike
    I own the dremel multimax, and havent noticed it getting too hot to handle. After a while it gets warm, but nothing to deter its use.
    I do find buying generic blades are useless, as they only last an hour. I believe I purchased some bosch blades recently and was satisfied with their performance.
    Human Test Dummy
    NH
    4,006
    I have been running my Dremel the last few days and have found like Mike said it can get to hot to use. But if you run the speed on 5 instead of 10 it doesn't heat up as bad.
    Stupid hurts.
    12,258
    Charles like you i was highly skeptical of this machine but i am now a convert. I got HF unit. Like Mike said wanted cheapest and its not an everyday kinda tool but it can do some great things when needed. I just recently bought a tile grout blade to redo some grout around here.
    Sent from my MB860 using Tapatalk 2
  1. Multi-Function Tool
    By Dan Mooney in forum Hot Deals
    Last Post: 07-10-2010, 10:23 PM
  2. multi tip tools
    By Stephen Bellinger in forum General Woodturning Q&A
    Last Post: 05-28-2010, 12:42 AM
  3. Good deal on Dremel oscillating multi-tool
    By Barry Richardson in forum General Woodworking Q&A
    Last Post: 09-04-2009, 01:18 PM
  4. Dremel Multi Max?
    By Jeff Bower in forum New Tools
    Last Post: 12-22-2008, 11:35 AM
