Results 1 to 10 of 19
Thread: Why is my key chuck spring loaded?
    May 2009
    Lafayette, Indiana
    2,380
    So I'm waiting on some epoxy to cure to make a new pen tonight so I thought I would kill some time and ask a question that I have thought about for some time. I bought this older 1970's (???) drill press a few years ago and the key chuck that came with it has a spring loaded pin built into it. WHY? My old drill press didn't have this nor does any other key's I own or have used have this. So my question is why does this key have a spring loaded pin? It has actually caused me to pinch my fingers with the chuck before trying to push in and turn it at the same time. So what am I missing?
    Thomasville, GA
    5,992
    A manufacturer's description in part: "...equipped with spring-loaded ejectors which ensure key disengagement after tightening."
    Kinda what one would think, I guess.
    Bill Arnold
    Constantine, MI
    7,890
    I believe it is your beloved big brother watching out for your safety. Leaving an un-sprung chuck key in the chuck and turning on the drill press can turn that key into a dangerous missile destined to poke out an eye, or worse. The spring keeps you from leaving the chuck key in place thereby removing the threat of losing any eye while simultaneously facilitating the pinching of fingers and the learning of new words with which to describe unfortunate shop experiences.
    www.wrworkshop.com
    May 2009
    Lafayette, Indiana
    2,380
    Well.....nerver thought of it. I guess you could leave it in and forget about it. I guess I just was always taught to take it out and it never even occured to me that someone might leave it in. Now, I have taken it out and laid it down and forgotten where I put it but I've never found it still sticking in the chuck.
    Thanks guys.
    12,247
    Tom what i did to avoid the lost problem is to put it on the end of a retractable zinger which i mounted to the drill with a magnet.
    Sent from my MB860 using Tapatalk 2
    Mar 2012
    SW Minnesota
    159
    Quote Originally Posted by Rob Keeble
    Thanks for the tip. I have a couple of extra retractors from fly fishing and a couple of rare earth magnets left over from a project.
    I've seen a chuck key embedded in a wall when a student failed to remove it from the chuck and another turned the drill press on. Lucky it went the direction it did.
    10,604
    I replaced the spring loaded one with an good old style chuck key. I got tired of the key slipping out and scraping my knuckles across the chuck when I tighten it.
    when I am done drilling I take the bit out of the press and chuck up the key so I know where it is the next time I want to use it.
    Feb 2012
    2,746
    I did wonder the same thing about my drill press, which is only a few years old. I like Rob's idea for keeping it from getting lost. There are many times I've loosened the chuck to take a bit out, then had to go looking to see what flat surface I put the key on. I am getting better at remembering to put it back in the holder between uses.
    Cheers,
    Roger
    Dec 2008
    Portland, Oregon
    1,898
    That's what I did with Mine! Keeps it very handy
ID:	66985Click image for larger version.
ID:	66983Click image for larger version.
    Jesus was a Woodworker
  1. loaded up on bits this last month
    By Dan Noren in forum New Systems and Builds
    Last Post: 09-01-2015, 11:53 PM
  2. Loaded up a lot in Finishing
    Last Post: 02-25-2014, 02:23 PM
  3. Loaded Chicken & Potato Casserole.
    By John Pollman in forum The Cook Shack
    Last Post: 09-04-2013, 01:26 AM
  4. Loaded up and ready, IT FIT!!!
    By Bill Simpson in forum General Woodworking Q&A
    Last Post: 07-09-2008, 01:43 AM
