Results 1 to 3 of 3
Thread: Elm (I think) Bowl
    New Jersey (Philadelphia area)
    39
    Elm (I think) Bowl
    Hello everyone...
    If you follow the construction forum, you know that I am just getting started in a new shop. It has been quite a while since I had some real turning time, so I decided to force it (put some other things on hold). The rusult is this bowl made from elm, I believe...
    I rough turned two blanks from the same log about a year ago, and decided to finish them this weekend. I completely finished the first one and the other just needs some final sanding and a coat or two of oil.
    Here is one of the rough bowls mounted on the lathe:
    I retrued the tennon befor mounting.
    here it is ready for sand paper.
Name:	Ready for sanding.jpg
ID:	5880 Click image for larger version.
Name:	Ready for sanding 2.jpg
    And here is the first one finished.
ID:	5877 Click image for larger version.
    The mushrooms are another project that I did real quick with my two daughters and their friends. I just cut up four maple branches and quickly turned the mushrooms. Then set them up in the grass with some paint. They had a great time, and I did as well.
    Thanks for looking, and comments are welcome.
    Attached Thumbnails Attached Thumbnails IMG_3703.JPG   IMG_3702.JPG   IMG_3707.JPG   IMG_3711.JPG
    15,815
    James, that looks fantastic, nice job, and them girls sure look happy too!
    30,231
    Nice job, James. That's a very pretty piece of wood, whatever kind it ends up
    being. I really like the contrast in the colors.
  1. A bowl and a bowl tweaker
    By hu lowery in forum Lathe Project Showcase
    Last Post: 11-03-2015, 04:07 PM
  2. Little Bowl
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 09-23-2010, 02:27 AM
  3. Bent my bowl gouge.. a 5/8" bowl gouge
    By Chuck Ellis in forum General Woodturning Q&A
    Last Post: 09-01-2010, 12:57 PM
  4. Bowl & pot
    Last Post: 07-31-2010, 12:12 AM
  5. first bowl
    By Joe Mioux in forum Turning Tool Questions and Show & Tell
    Last Post: 08-02-2009, 01:13 AM
