Results 1 to 5 of 5
Thread: ply wood cabinets
    Nov 2010
    Richmond, MI near Port Huron
    64
    ply wood cabinets
    When building plywood cabinets such as for a rolling shop cabinet. I'd like to rout a dado for shelves and partitions. What glue is best for this type of construction. Standard yellow wood glue or construction adhesive. I'm thinking I should back the joint up with screws. Comments?
    17,475
    yelo glue is fine with or without screws.
    Sep 2007
    Plainwell, Michigan
    4,857
    Yellow glue is fine Guy, I use tightbond 1 backed with 1 1/2" screws for mine
    5,172
    Yellow glue. Construction adhesive is too thick IMHO for construction other than with dimensional lumber.
    Screws are optional. That said, if my cabinet is on wheels, I add screws. If I am hanging the shop cabinet on cleats and it will get moved, it gets screws. If it is just fastened in place, then maybe no screws.
    I also plug the screw holes. It gives me practice for when I need to do it on 'real' furniture. Counterboring the hole without tearout. Cutting plugs. Aligning and matching the plug grain. Trimming the plug for a smooth final surface. Sounds like a lot of work, but practice cuts the job to size. Invaluable when the project is fine furniture and the wood is expensive.
    Oct 2009
    Lindale, TX
    84
    Yup, yellow glue. Screws in your application are just clamps, once the glue dries the screws don't really add anything to the strength of the joint.
  1. Choice of wood for kitchen cabinets
    Last Post: 08-11-2010, 07:58 PM
  2. Mappa burl cabinets....Phase II update cabinets installed
    By Alan Bienlein in forum Flatwork Project Showcase
    Last Post: 05-23-2009, 06:15 PM
  3. Cabinets and SU
    By Gregory Hairston in forum Designs, Plans and Sketches
    Last Post: 12-09-2008, 12:28 AM
  4. We have CABINETS!
    By Don Taylor in forum General Woodworking Q&A
    Last Post: 11-26-2007, 11:44 PM
  5. A Diamond in the Rough: Using Salvaged wood for Custom Cabinets
    By Chris Mire in forum General Woodworking Q&A
    Last Post: 11-12-2007, 07:32 AM
