Ken Cook
so ken how did you decorate that saw handle push stick
Larry, the leaf/vine was done with a cheap burner kit from a craft store the Mrs uses called Micheal's...
kit> tips used> sure beat my first attempt>
The lettering was from a stamp set I've had for some time, If I recall correctly, they came from Rockler, if not it was probably sears...
On another note...I did attempt a miter slot hold down, before the mallet & Push stick...it was coming along OK, until...I had made the finger board too long ...needless to say, the miter saw, radial arm saw & the table saw are not the proper choice, in trying to trim the already cut fingers down/shorter & being as I had joined the last 2 pieces of maple I had on hand to make this one...it was pushed to the back burner...
