Results 1 to 8 of 8
Thread: I knew better
    11,833
    I knew better
    Making a little project for my church.
    Need to fit 3/4" dowels into holes. Without thinking I bored 3/4" holes with a Forstner bit.
    Of course, the dowels don't fit. So, I reduced the ends using my 1" belt sander/grinder. Not the neatest or best way. I really don't want to buy a set of drills or Forstners that are all 1/16" inch over common sizes. In this case it would 13/64th.
    Wadda y'all do?
    BTW, pic of project later.
    Been there and done that, but I think I would have used my lathe to reduce the ends of the dowels.
    17,475
    have used a drill press to do the resizing over this way ..
    Thomasville, GA
    5,998
    And all this time I thought all of them good ole boys in Arkansas knew how to use a pocketknife for everything!
    Seriously, I've used a sanding block to knock some dowels back a little.
    Bill Arnold
    new york city burbs
    10,188
    Im not sure where you got the 13/64th, I must be missing something frank. must be why my measurements are always messed up.
    when I make things with dowels that need reducing a pinch at the ends, I clamp a piece of wood on my TS, raise the blade a smidgen at a time and roll the dowel (with a stop block) back and forth over the blade. Keeps it nice and round.
    Human Test Dummy
    11,833
    Wouldn't go through my chuck and arbor and I don't have a center steady for this lathe. Of course, my first instinct was to use the lathe.
    13,460
    If I had the larger forstner, I'd drill a hole with it in some scrap, then line up the scrap with the hole spaced over the smaller hole and use the scrap as a guide, fixed to the work piece of course. If not probably as you did if a lathe wasn't available.
    Having now seen the finished project, I can see how mounting the long dowels could be a problem.
    In the past, I've had to make a bunch (100+) of 2 1/2" long tapered dowel pegs for my brother-in-law's Viking tents and furniture. Fortunately, the diameter of the dowels was small enough to feed through the spindle of my lathe, and I could grip it with a chuck. I'd feed about 3" of dowel through the headstock, tighten the chuck a bit, take a few passes with the skew, then use a saw to cut off the tapered peg. Once I got a system going, I was cranking out a peg every minute or two.
  1. I just knew it!!!
    By Bart Leetch in forum Off Topic Discussion
    Last Post: 08-24-2015, 09:50 PM
  2. i knew it was coming....
    Last Post: 05-02-2012, 04:36 PM
  3. Never knew these even existed...overhand rip saw
    By Rob Keeble in forum Neander Tool Questions and Show & Tell
    Last Post: 09-06-2011, 03:01 AM
  4. To be, or not to be. Alas, I knew him... Rant
    By Rennie Heuer in forum Off Topic Discussion
    Last Post: 10-31-2010, 05:19 AM
  5. 50! Who knew?
    Last Post: 03-27-2007, 02:14 PM
