http://www.ptreeusa.com/edirect_050412.htm
Use key code "TOG@" when you place your first item in the cart.
Last edited by glenn bradley; 05-05-2012 at 12:57 PM. Reason: Forgot to tell you the key code . . doh!
Be excellent to each other. - Rufus
Stand firm for what you believe in until, and unless, logic and experience prove you wrong.
ok glenn how many do you have and what style? can the larger one still clamp thinner stuff?
I tried to place an order and it uses the regular prices for the clamps. Shipping is kinda steep, too.
Bill Arnold - Website - ShopCam
Food for Thought: The Ark was built by amateurs, the Titanic by professionals.
Ignorance is only skin deep, but stupid goes all the way to the marrow!
Live every day like it's your last, but don't forget to stop and smell the roses.
Sorry guys. I forgot to tell you the code. Use "TOG2" as the key code after adding the first item to your cart.
Larry, I use the low profile ones, mount them to a block to elevate them and then use longer posts for a greater range of reach. Once the foot is within range of the thicknesses you want to clamp, the pressure is consistent throughout that range. That is, if I set the foot length to clamp a 1/2" material, it will now clamp 5/8", 3/4", 1" etc. with the same pressure. Clever little gadgets and handy for the types of things I do.
what length of foot glenn the 2" ones or the 6" ones?
I buy the 6" ones (they go on sale pretty regular) and then actually cut them down a bit. I racked my knuckles many a time before I finally surrendered and cut an inch or so off of the ones on the jig shown. The little plastic caps are from fiber optic connectors that we use at work but, a little plastic dip, duct tape or nothing at all can work tooPrior to finding the long posts on sale, I used carriage bolts with a little rubber door stop pad (picked up at one of Lowe's Sunday clearance table blow-outs) stuck to the end with a squirt of silicone rubber:
