Results 1 to 10 of 27
Thread: Entertainment Center
    Mar 2010
    Decatur, Alabama
    506
    I've finally started working on my entertainment center. I started looking into this project last summer. Since then I've asked a lot of questions, looked at a lot of pictures for design ideas, and changed my own ideas a good bit. Here is the rough sketchup model. The bottom half of the sketchup is complete. The top half will have some type of crown, arched tops of some radius, probably fluted columns, and panels on the ends. I am also gonig to put a dimmer and some lights into the top.
Name:	Entertainment Center1.jpg
    I'll update the sketchup more later. I'm pretty firm on the height/width of the top sections, but the details are still up in the air. I started veneering the plywood for the bottom boxes a couple weeks ago. I'm not sure I have the perfect amount of glue down pat, but I have definitely learned what to much and to little look like It's not the fastest moving project I've ever done, but the veneer is turning out good now. It's going to be one huge chunk of walnut when I'm done, with the end panels and some of the FF from Larry's stash.
ID:	67269Click image for larger version.
    7,703
    I like your design Jeb. Looking forward to following along
    Asking a stupid question is better than repairing a stupid mistake.
    14,461
    well jeb you need to show us what to much and not enough looks like
    6,737
    Alright. This will be a great follow along Jeb. Nice proportions. Will the larger "rails" across the tops of the three sections will be for the crown?
    Be excellent to each other. - Rufus
    Stand firm for what you believe in until, and unless, logic and experience prove you wrong.
    Thomasville, GA
    2,141
    Nice design, Jeb! I'm looking forward to following your build.
    Bill Arnold - Website - ShopCam
    Food for Thought: The Ark was built by amateurs, the Titanic by professionals.
    Ignorance is only skin deep, but stupid goes all the way to the marrow!
    Live every day like it's your last, but don't forget to stop and smell the roses.
    Mar 2010
    Decatur, Alabama
    506
    Yeah, the sketchup just isn't final yet. I'm not 100% sure what I want my crown and arches to look like, but it's going to have some form of crown molding at the top and an arched top rail on each of the three sections. Part of it is deciding what cutters I might buy to make the crown. I've looked at just combining a cove cut and some router bit profiles, or the twin router bits from freud for 5.5" crown.
    Larry - I'll see what I have. It was a pretty busy time on my first few panels trying to get everything into the vacuum press, then scrambling to fix the one that had the bubble in the center, so no pictures of the repair. I'll take one of the finished repairs when I get back out to the shop.
    Feb 2009
    Magnolia, Texas
    1,810
    Are you using paper backed veneer? If you are I've found it adheres better if you take a ros with 120grit and scuff the paper. As far as the amount of glue put a pencil line on the substrate and when you can just see it thru the glue you have enough on it. Are putting a platten on top before you put it in the bag or are you just relying on the bag for the pressure?
    Mar 2010
    Decatur, Alabama
    506
    Quote Originally Posted by Alan Bienlein View Post
    I'm using breather mesh on both sides that I got from veneersupplies.com, and all raw wood veneer. The area I wasn't getting enough glue on was the edges, some spots just weren't adhering good enough. I didn't notice until I had a piece chip out. Click image for larger version.
ID:	67287 It wasn't to hard to fix where it wasn't chipped, just a razor blade to lift the edges up and spread glue under them. This piece is just the inside of a lower cabinet, so I'm just planning on a little dyed sealer to make it blend in a little better. I've been leaving my panels a little oversized then cutting after I veneer them. Is this the normal way of doing it, or do you normally cut the panel to the exact size then trim the veneer down after the press?
    There was a spot on one panel that had a bubble of glue under it when I pulled it out of the press. I ended up slicing it with a knife to get the excess glue out, then cutting a piece shaped about like a toothpick out to get it to flatten back out. This worked really well with the dark tinted veneer glue I am using, just left a dark line after I scraped and sanded the area. Before I cut it, it looked like there was a quarter under the veneer
    Today I put the first couple face frames together, sanded, and applied a dye stain. The natural color doesn't really show up well on camera, but there's a very distinct difference between some of the boards. I mixed a walnut transtint dye at about 1/4 strength and I think the boards are close enough now. I wish I could leave it all natural, but there's to much color variation between pieces for our taste.
ID:	67286Click image for larger version.
    Mar 2010
    Decatur, Alabama
    506
    Here is what I was thinking on the sides of the upper half. I had planned on raised panels everywhere (not going to draw those in sketchup for now). I'm not exactly sure what to do about the side panel here. I think the top rail should be as high as the arched face frame on the front of the entertainment center. It's drawn at 2" high, but the arched panel is 5" high on the edges.
Name:	Entertainment Center2.jpg
ID:	67288Click image for larger version.
Name:	Entertainment Center3.jpg
    Should I make the raised panel on the sides arched at the top, or just make the top rail about 5" x 9" instead of 2" x 9"? Any other ideas on how do deal with this visually?
    Feb 2009
    Magnolia, Texas
    1,810
    I've always cut my panels and veneer about an inch larger and cut to size after I glue the veneer on. I also always try to use a scrap piece of 3/4" material when ever possible the same size as my panel when ever I put it into the vacum bag. As for the breather mesh I just got some felt from the fabric store that I then put over the top. Here is a pic of my setup.
    In the picture you can see the yellow tub that goes in the left side. That is the line to the vacuum pump. It goes thru the bag and into a 3/8" hole drilled about 3" deep into the edge of the 3/4" platen. The platen has 1/8" x 1/8" grooves cut on the top and bottom in a grid pattern that has one set that intersects where the vacuum tube is insert and a 1/8" hole is drilled thru the groove thru to the 3/8" hole. This allows an even vacuum under the piece without having to use some type of breather mesh underneath. 45 minutes later I pull it out and the next one goes in. I then sticker my panels for a couple of days to allow them to cure and then cut to size.
