Results 1 to 7 of 7
Thread: Plane chatter
    Feb 2012
    2,749
    Plane chatter
    My #4 plane (copy of a Stanley) is working pretty well, but I get a bit of chatter in some spots. Am I correct in thinking that moving the frog forward to narrow the throat will help?
    Cheers,
    Roger
    Sep 2007
    Plainwell, Michigan
    4,857
    Are you waxing the sole?
    May 2011
    Cape Cod, Ma.
    1,553
    give it a try. you may not have enough of the blade supported. try shallower cuts as well. do you notice any difference in the grain where the chatter occurs? That can also be a factor.
    4,701
    Also try adjusting the chip breaker closer to the edge.. There was a pretty enlightening thread a day or so ago on SMC in the neatherthal haven about that - "Influence of the Cap-iron on Hand Plane" search google shows the video.
    Feb 2012
    2,749
    Thanks! I'll give it all a try. The cap iron is less than 1/16 from the edge of the blade, but I haven't waxed the sole lately.
    Cheers,
    Roger
    5,323
    Roger,
    You didn't say what wood the plane is chattering on, or what type of grain. Figured woods, or very hard ones often cause chatter. Among the domestic woods, figured maples (birdseye curl, quilting) are among the worst.
    Most of what you've been told already is good advice, although I've never felt that waxing the sole reduces chatter. It does make the plane easier to push, though.
    1. take very light cuts.
    2. if the wood has figure in it, or 'reversed' grain patterning, then try planig from different directions.
    3. try wetting the wood slightly - just a light spritz, or a wipe with a wet rag.
    4. keep the plane's mouth as tight as possible.
    5. keep the chipbreaker about 1/64" (~0.3mm) from the blades edge
    6. sharpen often.
    7. Since you don't have a high angle frog for your plane, try putting a 3~5 back bevel on the blade. This, in effect, will give you a higher planing angle which iften helps in hard or figured woods.
    12,262
    Roger have you ever tuned up your #4. If so did you check that the chipbreaker part of the cap iron is making contact with the blade across the full length of its contact area. Also how tight do you have the lever cap screw that enables the lever cap to exert clamping force on the whole blade cap iron etc. If its not securly held and you come across testy wood that too will cause the chatter.
  1. Plane gloat - rabbet plane
    Last Post: 03-21-2012, 09:08 PM
  2. Flush Plane / Flat Chisel Plane
    By Richard Line in forum Neander Tool Questions and Show & Tell
    Last Post: 10-06-2009, 09:12 AM
  3. Larry Marley Chatter tool
    By laurence moughan in forum Turning Tool Questions and Show & Tell
    Last Post: 01-29-2009, 09:51 AM
  4. chatter in oak
    By Jiggs Elphison in forum General Woodworking Q&A
    Last Post: 07-26-2008, 01:37 PM
  5. Homemade Chatter Tool
    By Joe Collazo in forum Turning Tool Questions and Show & Tell
    Last Post: 03-02-2007, 08:48 AM
