Results 1 to 5 of 5
Thread: Switch Wiring
    Zushi, Japan
    739
    Switch Wiring
    My switch on my TS has finally bit the dust. I have a replacement ready but I want to confirm the wiring on it as I am so prone to making the kind of mistakes where I'm left scratching my head after blowing the motor or something like that.
    Below are some photos.
    Obviously if I use it for single phase then I use two terminals each side and for three phase three on each side. But what about the ground wires? Do I have to find a grounding terminal separate from the switch? And is it the black wires that go on the load side?
    This is the new replacement. Made for Woodtech (Woodworker.com)
    Single or three phase.
    The terminals. Says LOAD on one side (bottom left of terminals).
    The old switch.
    You never break the ground, just the hot and maybe the neutral. The motor goes on one side of the switch "Load" and the in comming line on the other side "Line".
    Bob
    Making saw dust in SW Louisiana
    13,439
    Bob is correct. I'd probably connect the two ground terminals together under one of the metal mounting bracket screws on either side.
    May 2009
    Poway, CA, near San Diego
    174
    Yes, Other Bob is correct. I would also check in the motor junction box that the ground wire in there is screwed to the metal frame of the motor.
    Bob
    Zushi, Japan
    739
    Thanks guys, that was just the clarification I needed. Switch now wired and operational.
  1. 220 V wiring question
    By Allen Bryant in forum Carpentry and Construction
    Last Post: 09-24-2014, 06:41 PM
  2. wiring in a new switch
    Last Post: 08-19-2014, 09:45 AM
  3. Wiring for my new DC.
    By John Pollman in forum Off Topic Discussion
    Last Post: 04-24-2013, 01:58 AM
  4. Switch Hitter vs Switch Pitcher
    Last Post: 06-17-2011, 12:53 PM
  5. wiring a reversing switch
    By Paul Hubbman in forum Old Iron
    Last Post: 07-21-2008, 02:58 PM
